15m Industrial Plasma Cutter
7 years 2 months ago #142828 by Jarman
Replied by Jarman on topic 15m Industrial Plasma Cutter
Thanks for clarifying Phill, that makes sense.
I ran man plasmac and got:
VERSION 0.66 - 19 Aug 2019
It also says "PLASMAC(9)" at the top but I don't know if that is version related.
7 years 2 months ago #142829 by phillc54
Replied by phillc54 on topic 15m Industrial Plasma Cutter
When was your last update?
The following user(s) said Thank You: Jarman
7 years 2 months ago #142830 by Jarman
It was this morning at about 9am (UK) time, 3.5 hours ago. I have been away and not using the computer since the 13/08/19 so I think when I updated this morning it updated to that version (ie. It did successfully update). Am I missing a version?
7 years 2 months ago #142831 by phillc54
Do you have a line in your machine HAL file beginning with loadrt [EMCMOT]EMCMOT and does it have num_spindles=2 at the end.
7 years 2 months ago #142832 by Jarman
I'm not entirely sure what is meant by machine HAL.
I have the file "plasmac.hal"
located: /usr/share/doc/linuxcnc/examples/sample-configs/by_machine/plasmac/plasmac.hal
Is this what you mean?
This file has the line:
"loadrt plasmac"
however I can't see a reference to the number of spindles. I have attached the file so you can see what I'm looking at.
Thanks.
File Name: plasmac.hal
File Size:3 KB
7 years 2 months ago - 7 years 2 months ago #142833 by rodw
Replied by rodw on topic 15m Industrial Plasma Cutter
Try this file instead of the one you have. Based on my experience today I would expect this to work. All I've done is comment out a pin you don't need as you don't have an engraver. as I mentioned earlier in this thread.
File Name: plasmac_20...8-22.hal
File Size:3 KB
EDIT: rename it to plasmac.hal
Last edit: 7 years 2 months ago by rodw.
Time to create page: 0.226 seconds
