15m Industrial Plasma Cutter
7 years 2 months ago #141155 by tommylight
Replied by tommylight on topic 15m Industrial Plasma Cutter
Thank you Rod, and sorry i forgot to mention that you do need at least 30A at 100%, as Rod mentioned. It would also help if it has current regulation, that way you can fine tune the best cutting at the fastest rate.
On a 15m machine every second counts, so some design ideas mentioned here will save you a lot of time and nerves later when using the machine.
The following user(s) said Thank You: Jarman
7 years 2 months ago #141161 by rodw
Replied by rodw on topic 15m Industrial Plasma Cutter
So it sounds like the XP45 would be an ideal machine.
To control current via RS485, make sure you have a PC with a serial port for a RS-232 to RS485 adapter. I've not played with RS45 but somewhere on this forum I read the USB to RS485 adapters are not very robust!
So while Tommy has outlined a good stepper solution, you may also like to check out Bob's Servo Plasma build.
forum.linuxcnc.org/plasma-laser/36667-bo...lasmac-build?start=0
He shows the Mesa hardware he's using and a bit about the servos he uses. I have no experience with servos.
7 years 2 months ago #141172 by pl7i92
Replied by pl7i92 on topic 15m Industrial Plasma Cutter
at that size and costs of the HARDWARE
there is no way around Hybrid servos that costs you only 25% more then a Stepper Setup
and 4NM is a overkill on Rack pinion
the Images above show clear the use of Grinded T10 like Racks this is what we used in shop
and you can get on a Mesa fast and precice motion
7 years 2 months ago - 7 years 2 months ago #141217 by Grotius
Replied by Grotius on topic 15m Industrial Plasma Cutter
Jarman,
For cladding the boilers... What is the size you need to cladd the boilers in Z and Y value?
X is 15m.
UK is the country of steam locomotives. The country with car companies like Aston Martin, Bentley, McLaren and so on.
The UK has some under-developped places i know. I was there 2 years ago.
The UK developped a plane that can carry up vertical on a war ship.. Very cool !!!.
In Holland we only have a old wind mill of 1650 at Kinderdijk. We sold all our tanks 10 years ago.
All what is left are rusty bridges, and rusty traffic sign's on the highway.
We pay so much to the state, nothing happens over here. It's a shame. I am done with this.
My wish is to be a non member of the dutch economy.
Last edit: 7 years 2 months ago by Grotius.
7 years 2 months ago #141224 by andypugh
Replied by andypugh on topic 15m Industrial Plasma Cutter
Grotius wrote: In Holland we only have a old wind mill of 1650 at Kinderdijk.
You have the biggest steam engine in the world.
www.haarlemmermeermuseum.nl/en/cruquius-...largest-steam-engine
Though it was made in the UK :-)
7 years 2 months ago #141413 by Jarman
Replied by Jarman on topic 15m Industrial Plasma Cutter
Thanks all.
I got my hands on a refurbished computer and am now at the stage of installing Linux and subsequently LinuxCNC.
Are there pros and cons to using Debian or Ubuntu?
I read that Ubuntu can be a little bloated / doesn't have quite as good support?
Once I have installed a Linux operating system, I am planning on installing Debian 9 Stretch. I am thinking of doing this becuase the 7 Wheezy is not compatible with ethernet Mesa boards which I will be using.
I was hoping someone could let me know if I am on the right lines?
Thanks.
Time to create page: 0.332 seconds
