- Thank you received: 7491
15m Industrial Plasma Cutter
7 years 3 months ago #141106
Those do not come in a roll ! Never.
If that is what you actually need to cut, at 15meters length, only the material for the table to carry that will cost you over 3000 plus work and welding.
You must mean 0.8 and 1.2mm, or ????
Replied by tommylight on topic 15m Industrial Plasma Cutter
Jarman wrote: The thinnest material to be cut is 8mm. The other is about 12mm.
The following user(s) said Thank You: Jarman
7 years 3 months ago #141108
I did.
A 1.5 meter gantry can be made very light and sturdy and with reduction even some stronger Nema 17 motors on both sides can move it at over 18 meters/minute. Done that at 2.7 meters gantry and 22 m/m, gantry consisting of a 2mm thick metal bent to C shape with a single HGR25 and a single carriage, with floating head.
Now there is some contradicting info here so the answers are going all over the place.
Please check what exactly is needed and let us know.
rodw wrote: I don't think anyone said steppers. As Tommy said, keep the gantry as light as you can.
I did.
- Jarman
- Thank you received: 8
7 years 3 months ago #141109
by Jarman
Replied by Jarman on topic 15m Industrial Plasma Cutter
Sorry about that, my mistake.
You're right, the thicknesses are 0.8mm and 1.2mm.
Other than that I think the information is correct:
15m x 1.25m with a thickness of 0.8mm - 1.2mm.
Thanks for all of your help. I'll look into Mesa cards and THC.
- Thank you received: 4153
7 years 3 months ago #141111
Replied by rodw on topic 15m Industrial Plasma Cutter
Mesa cards with ethernet.
For steppers 7i96 is a good card for plasma but you probably need to share limit switches on one input.. Also the 7i76e has a lot more inputs and is what I use. But the 7i96 was not around then.
For servos, the card of choice is the 7i77 but it is not an ethernet card so you need to connect it via a 7i92.
All of these cards have virtually unlimited expandability via the smart serial interface (up to 1024 inputs and 512 outputs from memory)
For smaller plasmas you need to look for something capable of 100% duty cycle at 40 amps from Hypetherm or Thermal Dynamics/ESAB. You probably will need a 60-80 amp one for that performance.
The THCAD-10 board is a voltage to frequency converter designed for the electrically noisy environments like plasma cutting. Each board is individually calibrated. It is connected to an encoder interface and we decode the frequency back to a voltage in software. Its remarkably accurate.
7 years 2 months ago #141115
That brings us back to what some of us mentioned above and excludes some other.
To recap :
-Very light gantry made with a single square metal tube 80X80 or 100X100 mm, with a single square rail and a single carriage, HiWin HGR 15 or 20, 25 is the upper limit, belt driven preferably with some reduction, Nema 23 motor ( 17 will do just fine if above 1.2A ). Total weight with all motors should not exceed 50KG.
-Floating head, also as light as possible, screw driven with Nema 17 motor, all-thread M6 or M8 will do just fine but at slower speeds ( if you can budget it, use 1605 or 1204 ballscrews), drawer slides with ball bearings are very good for this, magnetic torch holder ( use magnets from old hard drives ), and very sensitive float switch so it triggers if it hits parts of material without breaking the torch.
-2 motors with reduction driving pinions on both sides of the gantry, Nema 23 2NM is more than enough. Ignore the 3:1 ratio, that will depend mostly on the pinion you use, so try to find the smallest pinion first, then calculate the reduction ratio to get 10 to 20mm per MOTOR revolution. You might end up needing 10:1 so buying 3:1 reduction might prove a bad investment.
-mounting the computer and controls and the plasma on the gantry is a very valid idea, but will greatly limit the maximum speed and acceleration.
-buy a small plasma, something like a Hypertherm 45, inverter as they are lighter, but do not buy a chinese one.
-Mesa 7i76E and THCAD
- supported round rails for the long axis on both sides, fi20mm are fine but use 3 carriages per side, 50 to 60cm total length for the carriages. You might want to use fi30 with 2 carriages per side but the price difference at 32 meters is quite big.
-you do need 31 to 32 meters of rails in total for the long axis, gantry will take the above mentioned 50 to 60 cm on both sides.
-Shielded cabling is a must.
-Drives, get Lam technologies DS1076 from mechapro.de at a significantly reduced price for the X and Y axis, DS1044 for the Z axis. 1076 work with higher voltage so you get much faster motor speed. They are indestructible.
-Metal work, that is for you to decide, and you have a lot of freedom on that part.
That is more like it, thank you.Jarman wrote: Sorry about that, my mistake.
To recap :
7 years 2 months ago - 7 years 2 months ago #141148
Tommy is the master of budget plasma builds and really knows his stuff.
At 15 kg for the inverter with careful design you should still be within Tommy's 50kg. I think my 1.22m gantry weighs about 32 kg including motors and gantry ends. It uses a 40 x 80 aluminium extrusion and 2 x HGR 15 rails with pinion drive. If I did it again I would just use one rail and probably go up to a bigger profile Tommy suggests but if you look at the Hiwin engineering specs, a single HGR 15 should be enough and probably save some weight.
Just watch the duty cycle. 100% duty cycle is 32 amps which is probably enough for your work. Also check the power input requirements, Single Phase ones require something like a 50 amp circuit which is huge for a single phase supply. So the three phase ones are much easier to wire in (12 amps or so).-buy a small plasma, something like a Hypertherm 45, inverter as they are lighter, but do not buy a chinese one
Last edit: 7 years 2 months ago by rodw.
The following user(s) said Thank You: tommylight, Jarman
Time to create page: 0.265 seconds
