Another plasma component...
- phillc54
- Thank you received: 2100
07 Aug 2019 05:50 #141583
by phillc54
I have done a bit of cleaning up and additions to the GCode parser, must have been a bit heavy handed.
Sorry about that.
Sorry about that.
- thefabricator03
- Visitor
07 Aug 2019 06:05 #141584
by thefabricator03
Replied by thefabricator03 on topic Another plasma component...
No worries Phill,
So what do you think the fix will be? Revert back to Old or modify the existing?
- phillc54
07 Aug 2019 06:09 #141585
by phillc54
Here is the latest up to date plasmac_gcode.py which I will push to LinuxCNC later.
It also fixes the lonely G0 issue and the extra stop code at the end.
If you have some time left after I have wasted a lot of it for you could you try out the pierce only feature, it is also included.
- Thank you received: 4149
07 Aug 2019 06:15 #141586
Actually, while you are wasting Stefan's he's saving my time !
Keep up the good work team!
The following user(s) said Thank You: phillc54, tommylight, thefabricator03
- thefabricator03
- Visitor
07 Aug 2019 06:29 #141588
by thefabricator03
Thanks Phill, That got me going.
- thefabricator03
- Visitor
07 Aug 2019 07:00 #141590
by thefabricator03
Ill run out a sheet of cleats tomorrow and Ill test the pierce only function.
- phillc54
07 Aug 2019 07:07 #141591
by phillc54
Thanks, I'm really interested in how it goes.
It would also be best for the tool you are using for piercing only to have the Cut Height set the same as the Pierce Height.
If it works out ok you could probably use end of life consumables for the piercing only then change to newer consumables for cutting only.
The following user(s) said Thank You: tommylight, thefabricator03
- phillc54
07 Aug 2019 10:18 #141604
by phillc54
I have pushed an update:
GCODE parser:
fix orphan G0 bug
fix M190 with comments bug
better error handling for materials
add 0 as defaults for non essential material variables (kerf width, THC, puddle jump, cut amps, cut volts)
add experimental pierce-only option (undocumented)
GCODE parser:
fix orphan G0 bug
- thefabricator03
- Visitor
07 Aug 2019 10:43 #141606
by thefabricator03
That is a REALLY good idea, I have a bucket I keep my used consumables in and I have a fair amount that would be suitable for piercing only.
- phillc54
08 Aug 2019 03:24 #141651
by phillc54
Stefan
The code you posted here doesn't look quite right to me.
There are a 294 F#<_hal[plasmac.cut-feed-rate]> codes when you only need 1 for the job.
There are a 289 M67 E3 Q60 (reduce feed rate) codes appearing before G0 codes and then having an effect on following G1 codes.
There are only 128 M67 E3 Q60 codes, I would think that there should be the same number of 60's and 100's.
There are 200 M62 P2 (DTHC OFF) (On small circles) codes. These probably should be where the M67 E3 Q60 (reduce feed rate) codes are used as the speed rduction will inhibit THC as well. (providing the VAD Threshold is above 60%)
There are 94 M63 P2 (DTHC ON) (On lead in) codes and 94 M62 P2 (DTHC OFF) (Before end) 94 codes which seems to make sense.
Time to create page: 0.297 seconds
