CNC Sewing machine question
7 years 2 months ago #141525 by rjd1234
Replied by rjd1234 on topic CNC Sewing machine question
Yes, I have seen that video. That is basically how mine is running now.
7 years 2 months ago #142000 by andypugh
Replied by andypugh on topic CNC Sewing machine question
No eBay APP ID and/or Cert ID defined in Kunena configurationI think that the way to do this is to use adaptive-feed to halt the fabric when the needle is down.
How do you know the needle position? The stepgen outputs a position. If you add homing for the spindle then you can use a custom HAL component to output the adaptive-feed ratio.
But how to home a spindle? Currently that's not built-in behaviour. But it could be part of your custom hal component
Have you seen the commercial sewing machine servos? They are surprisingly cheap, and have a rudimentary encoder:
as an example, Cheaper ones exist, and more expensive more powerful ones too.
I think I would be looking to use one of those, and then try to work out the adaptive feed from the needle-up signal and some cleverness in a HAL component.
The stepper should work, but the dedicated motors are a lot more powerful.
Tell us which way you want to go, and I think we can come up with something.
6 years 9 months ago #154303 by ahmetbm
Replied by ahmetbm on topic CNC Sewing machine question
I am sorry if here is not the right place to ask this question.
I am developing a cnc sewing and cutting machine.
I am using 2 different motors to move hook and needle seperately as an axis(Z and A) and 2 other motors for x-y movement.
However i have a problem, what should i do when thread is broken?
Thanks.
6 years 9 months ago #154305 by andypugh
You could trigger a program-pause.
halui.program-pause
linuxcnc.org/docs/2.7/html/man/man1/halui.1.html
6 years 9 months ago #154308 by ahmetbm
andypugh wrote: You could trigger a program-pause.
halui.program-pause
Thank you.
How can i be sure the needle is at top position?
In other words how can i pause when needle and hook motors are complated revolution?
6 years 9 months ago #154310 by andypugh
How are you controlling the machine? Is the needle slaved to XY?
Time to create page: 2.859 seconds
