Control Panel Wiring
  • Dinuka_Shehan
  • Dinuka_Shehan's Avatar Topic Author
  • Platinum Member
  • Platinum Member
23 Aug 2019 10:23 - 23 Aug 2019 10:48 #142934 by Dinuka_Shehan
Control Panel Wiring was created by Dinuka_Shehan
I just wiring my diy cnc lathe control panel
I attach all components in to piece of wood and hook it to metal panel.
use some 3 core wires and computer psu cables for signal wires.
24V 15A supply for motors and 12V external supply for cooling fans,
add a estop for emergency purpose.
contactor for 3 phase motor and TB6600 drivers use motor stepper motors,.
add a 2 pole breaker for switch the power supplies,
5 axis breakout board used for my project!
little messy but it is my first time,trying to eliminate faults next time.
how can I control 3 phase motor via bob(bob onboard relay to power the 22OV contactor coil)?
I want to use M3 and M5 to CW and Stop the spindle>
any ideas?
Last edit: 23 Aug 2019 10:48 by Dinuka_Shehan.
  • Moderator
  • Moderator
23 Aug 2019 11:00 #142940 by tommylight
Replied by tommylight on topic Control Panel Wiring
1x 470 ohm resistor
1x darlington transistor NPN
1x smal 12V or 24V relay
Check your BOB if it outputs 5V when that output is turned on from the computer. This is for BOB's with buffer IC's, for the ones with opto outputs the resistor should be 1K and the wiring is slightly different.
  • Dinuka_Shehan
  • Platinum Member
  • Platinum Member
23 Aug 2019 11:24 #142943 by Dinuka_Shehan
Replied by Dinuka_Shehan on topic Control Panel Wiring
Bob have relay
Can’t I work with it
  • Moderator
  • Moderator
23 Aug 2019 12:55 #142948 by tommylight
In that case you should add another relay so the 220V is not wired to the BOB.
I do not trust these BOB's.
Is the big motor relay 220 or 24V opetated ?
If it is 24V you can wire it to the relay in BOB.
The following user(s) said Thank You: Dinuka_Shehan
23 Aug 2019 14:24 #142955 by pl7i92
Replied by pl7i92 on topic Control Panel Wiring
hi i did a video on the BOB and VFD wirering
it may help you
Font forget the 12-24V wirer for input and use the VFD error back to get motion only on full Spindle speed or a error regioniced
  • Dinuka_Shehan
  • Platinum Member
  • Platinum Member
23 Aug 2019 14:33 #142960 by Dinuka_Shehan
contactor coil 220V
you tell about safety precautions?
  • Dinuka_Shehan
  • Platinum Member
  • Platinum Member
23 Aug 2019 14:46 #142963 by Dinuka_Shehan
I have got 5V relay
  • Dinuka_Shehan
  • Platinum Member
  • Platinum Member
23 Aug 2019 14:49 #142966 by Dinuka_Shehan
i don't use a vfd
23 Aug 2019 14:52 #142967 by pl7i92
i woudt also go via a industrial Relay so double safty
like finder 40.52 that are made to get full 240V 50Hz
ARDUINO in use for 24V to the Power relays bottom Right down
  • Dinuka_Shehan
  • Platinum Member
  • Platinum Member
23 Aug 2019 15:02 #142970 by Dinuka_Shehan
what is the mesa card you are used here.
my spindle wiring is
live(hot) to bob relay common
when turn on relay live connected to 220V contactor A1(coil of contactor)
neutral to A2 of contactor
then start the motor.
is output pin enable 16 or 17 to show spindle rotating or not?
Time to create page: 0.607 seconds
