Need help with Proma file install
- pl7i92
- Thank you received: 358
05 Sep 2019 07:03 #144220
by pl7i92
Replied by pl7i92 on topic Need help with Proma file install
yes somtimes it brings more trouble to the system if you use compnents
ore even full aligned systems Plasmac
it is very easy as you only got min 2 pins -> up down
or the tird arc-ok
this can be crossed by m3 so no pin needed
gcode does wait G4 P1 to start
here we are working that way
as we got only 5 inputs to the mashine
1 all Ref limit
2 Touchoff
3 up
4 down
5 waterlevel low
or the tird arc-ok
1 all Ref limit
2 Touchoff
3 up
4 down
5 waterlevel low
- TexasCNC
- Thank you received: 10
05 Sep 2019 20:33 #144270
by TexasCNC
Replied by TexasCNC on topic Need help with Proma file install
I finally got the axis to load up but when I toggle to machine power I get the eroor of joint 2 is on limit switch or something like I dont remember not in front of it right now. I just want to get this going working. They told me it was a float switch that was the issue n the error but I checked the config and it looks ok. Also I am trying to add the A axis on it as well cause I Have 2 motors ont he Y axis and when I go to edit file to add them and go to other file enable the pins it gives me a error as well So I got the gui to open up with keeping it at 3 motors but I need the 4 motor to work. any suggestions or ideas of what I can do?
- Thank you received: 7468
05 Sep 2019 21:08 #144277
Replied by tommylight on topic Need help with Proma file install
- TexasCNC
05 Sep 2019 21:33 #144281
by TexasCNC
Yes I did that already and none were helpful to what I am looking for. Opened a thread to see what the experts would think.
Time to create page: 0.082 seconds
