How to select Mesa boards for my CNC project.
- Chris D
26 Sep 2019 13:37 #146254
by Chris D
How to select Mesa boards for my CNC project. was created by Chris D
Good morning all,
I am new to LinuxCNC, been using Mach3 for years but now want to move on from that product. I am watching the Raspberring pi thread as I see great potential to use it for the computer hardware to run LinuxCNC.
I have read a lot of the documents and watched a lot of videos, and read a good amount of the threads on this forum, but I am still stuck in the planning phase of my project.
It looks to me like using a Mesa board is a good idea, especially because I am going to use a RPI-4 as the host computer. I have spent a lot of time on the Mesa websites but I simply cannot wrap my head around the selection process of which board / daughter board to select for my project.
Can someone walk me through the process of selecting the correct board(s) to be used?
For reference, this is what I am re-controlling with LinuxCNC.
Thanks much in advance!
Chris D
- 2 Axes lathe (X,Z), stepper driven, Step & Dir signals
X - Step
X - Dir
Z - Step
Z - Dir
X axis limit/home switch
Z home / limit switch
VFD spindle drive
FWD/REV
0-10V for speed
Spindle encoder for precise threading
Encoder 'A'
Encoder 'B'
Encoder - Index
E-Stop input
Cycle start button
Feed hold button
Spindle speed override (pot or encoder switch or ?)
Feedrate override (pot or encoder switch or ?)
Jog rate override (pot or encoder switch or ?)
Buttons to jog (X+, X-, Z+, Z-)
2 MPGS to allow for "manual machine" operation
X MPG 'A'
X MPG 'B'
Z MPG 'A'
Z MPG 'B'
MPG increment = .0001
MPG Increment = .0010
MPG Increment = .0100
Chris D
- pl7i92
- Thank you received: 358
26 Sep 2019 13:43 #146256
by pl7i92
Replied by pl7i92 on topic How to select Mesa boards for my CNC project.
as you already use mach3
it woudt be very easy to get the system to a 7i96 Mesa Board
or guessing you use 2 Parports simply use a 7i92H
if you are in Europa see the eusurplus for gettung parts
- Clive S
- Thank you received: 486
26 Sep 2019 16:53 #146285
by Clive S
Replied by Clive S on topic How to select Mesa boards for my CNC project.
If you want to go down the Ethernet route I would go with a 7i76e that would give you everything you need.
store.mesanet.com/index.php?route=produc...oduct&product_id=290
- Thank you received: 4149
26 Sep 2019 18:54 #146295
X 2
Possibly a bit overkill in regards to the number of inputs but it supports 2 MPG encoders plus dedicated spindle control with encoder input. The 7i96 is nice, but has fewer inputs and isolated relays built in on the outputs but I don't think it covers your 2 x MPG's
Replied by rodw on topic How to select Mesa boards for my CNC project.
X 2
26 Sep 2019 19:02 #146296
Probably a bit early Here is how to get your MPG's running on a 7i76e
forum.linuxcnc.org/show-your-stuff/32029...build?start=20#85305
I ended up with with a single 6 axis jog wheel on a pendant and have thought about using the unused 3 axis selections for overrides etc. You could do this as well on both MPG's
- Chris D
27 Sep 2019 02:57 #146320
by Chris D
Replied by Chris D on topic How to select Mesa boards for my CNC project.
Thank you all for the responses.
So, if I understand this correctly, the MESA board must have actual MPG inputs in order to connect an MPG?
Also....
"four input pin voltages are readable with 8 bit resolution"
I assume this means that the board provides 4 analog inputs?
Chris D
Also....
Chris D
- Thank you received: 1476
27 Sep 2019 12:51 - 27 Sep 2019 12:53 #146375
Replied by Todd Zuercher on topic How to select Mesa boards for my CNC project.
An MPG can also be used with ordinary hardware encoder inputs, or using any ordinary inputs using a Hal's software encoder interface.
linuxcnc.org/docs/html/man/man9/encoder.9.html
(and yes that does mean analog)
Last edit: 27 Sep 2019 12:53 by Todd Zuercher.
- pl7i92
27 Sep 2019 14:51 #146401
by pl7i92
as well you can use the standards of XHC-WB04 axis Mach3 Handheld
there are components that support this MPG if needed
prior is the Amount of rewirering you like to go
there are eays plug and play versins that may fit yur system already
OR as so many Mach3 Upgreaters to Linucnc will get a better performence use the called 7i76e upgread
with the 7i92 you are at the same system that you worked on within 1minute as the WIZARD will change the Mach3 config to a running
linuxcnc config
linuxcnc config
- Chris D
29 Sep 2019 13:43 #146560
by Chris D
Thanks for the information and answers!
Sorry to keep asking but even after a lot of reading, I am not confident I am anywhere near having a solid understanding.
I loaded the GMOCAPY lathe GUI and it looks really great. Is it safe to assume that any of the mesa boards will work with any of the GUIs? I think the area that confuses me is for example, I don't see MPG functionality on that GUI, but the boards I am looking are capable of MPGs and I certainly need them.
CHris
CHris
03 Oct 2019 00:39 #146921
Replied by andypugh on topic How to select Mesa boards for my CNC project.
I wouldn't suggest a Raspberry Pi for your first linuxCNC installation. It is still a bit experimental. And whilst it is usable you probably will find it no better than Mach3, and with a slower experience than Windows.
