Anybody using a thermal dynamics CM 52?
- TexasCNC
- Thank you received: 10
29 Sep 2019 00:21 #146526
by TexasCNC
Anybody using a thermal dynamics CM 52? was created by TexasCNC
Been using this machine but can’t seem to get it dialed in I have dry air and new consumables but some reason the cutting charts on manual has the voltage high for the THC. Any out there using this machine with a proma THC?
- Thank you received: 7468
29 Sep 2019 07:38 #146538
Replied by tommylight on topic Anybody using a thermal dynamics CM 52?
What is the actual issue ?
- TexasCNC
29 Sep 2019 20:23 #146621
by TexasCNC
Replied by TexasCNC on topic Anybody using a thermal dynamics CM 52?
I am getting bevel cuts on pretty much every settings on machine and thc. On 40 amp with 75psi all consumables are oem brand. Just want to see what people are using with this setup
- TexasCNC
29 Sep 2019 21:25 #146626
by TexasCNC
Also if I set the cut height to .19 per manual and do the same on the plasma config tab on axis GUI. Wouldn’t that change if I am setting the THC voltage to say 94 volts wouldn’t that move the cut height lower or higher to have it 94v? And when it’s cutting the voltage is never 94v I see where it’s trying to stay at 94v but mostly is like plus or minus 5v from my set voltage is there way to keep it tighter like maybe plus or minus 2 volts?
29 Sep 2019 22:41 #146636
Yes, set the Proma THC as per manual to 1v+- i think it was, also the DT to minimum.
- TexasCNC
29 Sep 2019 22:48 #146638
by TexasCNC
Ok I will do that thanks... and what about setting the height? Do I need to set it even though I am setting the voltage?
- phillc54
- Thank you received: 2100
29 Sep 2019 23:35 #146645
by phillc54
For PlasmaC Mode 2 (External THC) then the Cut Height in the Cut Parameters will only be valid from the start of the cut until the external THC takes control. So you still should set it so the cut begins at the correct height.
Replied by phillc54 on topic Anybody using a thermal dynamics CM 52?
I didn't realise you were using a Proma for your THC when I answered your question on another thread.Ok I will do that thanks... and what about setting the height? Do I need to set it even though I am setting the voltage?
- TexasCNC
29 Sep 2019 23:55 #146649
by TexasCNC
PlasmaC mode 2? Sorry I forgot how do I know what I have?
- phillc54
29 Sep 2019 23:59 #146650
by phillc54
Have a look in the .ini file in the [PLASMAC] section there should be MODE = 2
If you are using an external THC you should be using Mode 2.PlasmaC mode 2? Sorry I forgot how do I know what I have?
- TexasCNC
30 Sep 2019 03:39 #146674
by TexasCNC
That’s right got it yes I am on mode 2. And I set the the proma to
HYS - 2
DT - 00.5
HU - 200v
Will that work good?
HYS - 2
DT - 00.5
HU - 200v
Time to create page: 0.173 seconds
