- LinuxCNC
- General LinuxCNC Questions
- Mesa 7I92 and 7i96 not on supported mesa cards list. Voyage of discovery?
- Louis Cypher
10 Oct 2019 06:31 #147613
by Louis Cypher
Mesa 7I92 and 7i96 not on supported mesa cards list. Voyage of discovery? was created by Louis Cypher
Dear Forum,
I am about to buy a Mesa 7i92 or 7i96 the next days. Searching the documentation on linuxcnc.org I didn't find any of those cars on the list of supported cards. I know that others are running these cars but what does that mean to me in terms of setup and configuration?
Best,
Markus
Best,
Markus
- Clive S
- Thank you received: 486
10 Oct 2019 08:04 #147617
by Clive S
Have you seen this forum.linuxcnc.org/27-driver-boards/3504...6-configuration-tool
Replied by Clive S on topic Mesa 7I92 and 7i96 not on supported mesa cards list. Voyage of discovery?
Dear Forum,
Best,
Markus
- Thank you received: 7480
10 Oct 2019 09:33 #147624
Replied by tommylight on topic Mesa 7I92 and 7i96 not on supported mesa cards list. Voyage of discovery?
They are both fully functional with Linuxcnc, and there are plenty of us using them daily.
And they do have the best support on planet earth, bar none, provided by PCW.
- Louis Cypher
10 Oct 2019 10:05 #147628
by Louis Cypher
Replied by Louis Cypher on topic Mesa 7I92 and 7i96 not on supported mesa cards list. Voyage of discovery?
Thanks for the great link. I haven't seen it. Obviously the forum is faster than the documentation
You helped me a lot guys! Thanks!
- pl7i92
- Thank you received: 358
10 Oct 2019 12:46 #147634
by pl7i92
Replied by pl7i92 on topic Mesa 7I92 and 7i96 not on supported mesa cards list. Voyage of discovery?
what mashine is it as you are on 2 cards to decide
the 7i92 needs some dauter card no matter what DB25
and the 7i96 is ready to use for a standard mashine setup
- Louis Cypher
10 Oct 2019 12:54 #147636
by Louis Cypher
It is a 3 axis machine (gantry type). It has been running on a Chinese 5 axis BOB until the PC died (still unsure why).
Currently it denies working on a new BOB (same model) due to maybe cabling errors and not enough voltage for all 4 drivers at others because the parallel port or the too high USB power consumption causes the PC to boot only when all cables are disconnected (or randomly? Didn't dive into that). So basically I am fead up with the LPT driven stuff. I lost months fiddling around with stuff that stops working after a couple of ours.
P.S.: I can catch myself thinking of going back to GRBL and arduino uno
10 Oct 2019 14:09 #147640
If the PC is not booting while the parallel port cable is attached, the bob is causing some trouble and you might end up with another dead PC.
- Thank you received: 5326
10 Oct 2019 14:37 #147642
Replied by PCW on topic Mesa 7I92 and 7i96 not on supported mesa cards list. Voyage of discovery?
I have seen something like this issue (no PC reset) when you accidentally
backfeed the PCs 5V or 12V supplies with external power.
- Louis Cypher
10 Oct 2019 17:53 #147645
by Louis Cypher
That is exactly what I am fearing. But currently it is powered by the USB, 12V is not yet connected. The 5 V supply is as well not connected. When I received the PC LPT was deactivated in the BIOS and it does only boot successfully if the LPT is set to automatic (even if no cable is connected). Hence, the PC might have an issue with the LPT as well.Not much luck with this LPT stuff!
That is why am going for a MESA. Ordered a 7i96 today.I hope that makes things much easier.
- Louis Cypher
11 Oct 2019 17:42 #147716
by Louis Cypher
@tommylight: you have been right. Yesterday the second PC died. Both PCs cannot mount the hardrive anymore and are basically plain dead. They only can run a live CD anymore. No idea what caused the damage since they died on a different electronics box, so one faulty BoB can not be the reason
- LinuxCNC
Time to create page: 0.177 seconds
