Latency mesage SOLVED !
7 years 3 weeks ago #147690 by macsddau
Latency mesage was created by macsddau
I have setup latency to maximum in stepconf because test were near 65000ns and I get this message :
I don't now how to resolve this. I'm a beginner in Linux world.
7 years 3 weeks ago #147698 by tommylight
Replied by tommylight on topic Latency mesage
Open the ini file in a text editor and change
Base_period
to something larger, try 100000 ( one hundred thousand )
7 years 2 weeks ago #147710 by Todd Zuercher
Replied by Todd Zuercher on topic Latency mesage
What PC motherboard and CPU are you using?
Have you turned off all power saving features in the Bios?
It is important to have the PC configured correctly when running real-time operations, but some computers just are not well suited for it. (maybe you have a bad one.)
If you are trying to use an older PC, failing hardware, especially hard-drives, can cause latency problems.
7 years 2 weeks ago #147787 by macsddau
Replied by macsddau on topic Latency mesage
Hi
The PC is made with :
- ASRock mini ITX J3355B mother board
- 4GB Ram G.Skill SO-DIMM DDR3L 1333 MHz
- Radeon HD4650 Graphic card
- WD Green 120GB SSD Drive
I have turn off all power saving feature in the BIOS. But I will check it.
7 years 2 weeks ago #147794 by macsddau
macsddau wrote: I have turn off all power saving feature in the BIOS. But I will check it.
Checked !
There is not a lot of settings in the BIOS, all fans are turned to full speed. Mother board has no fan and chassis fans are connected to power supply.
7 years 2 weeks ago #147795 by macsddau
tommylight wrote: Open the ini file in a text editor and change
Base_period
Changing to this value will remove the message but it is not sure that the CNC will work fine.
Time to create page: 1.093 seconds
