- Thank you received: 49
Latency mesage SOLVED !
- Himarc3D
6 years 2 months ago #178961
by Himarc3D
Replied by Himarc3D on topic Latency mesage
Hi, where you found the calculator?
- macsddau@linuxcnc
- Thank you received: 29
6 years 2 months ago #178978
by macsddau@linuxcnc
linuxcnc.org/docs/2.7/html/motion/tweaki...rs.html#_no_guessing
And the direct download link
wiki.linuxcnc.org/uploads/StepTimingCalculator.ods
Replied by macsddau@linuxcnc on topic Latency mesage
Here in the documentation :Himarc3D wrote: Hi, where you found the calculator?
The following user(s) said Thank You: Himarc3D
- macsddau@linuxcnc
6 years 2 months ago #178986
Get the latency message
Running latency test again without any change.
- Thank you received: 7491
6 years 2 months ago #178988
Replied by tommylight on topic Latency mesage
Raise the Base_period in the ini file a bit then test again. Raise it until you do not get any latency warnings for at least an hour or two.
- macsddau@linuxcnc
6 years 2 months ago #178991
This morning. I run test. I get over 400ms while I was running full update with sympatic manager (some linuxcnc packages are not available). I suppose that very bad time was caused by the update. I reset test. Before that it was about 25.5ms.
6 years 2 months ago #178992
uname -a ?
What PC ?
How much memory ?
What PC ?
How much memory ?
Time to create page: 0.457 seconds
