- Thank you received: 7491
Latency mesage SOLVED !
7 years 2 weeks ago #147802
Replied by tommylight on topic Latency mesage
It will work fine, so change it.
While you are getting the error, that causes lost steps, usually not noticeable if the latency is not bad, very noticeable if latency is really bad.
- macsddau
- Thank you received: 4
7 years 2 weeks ago #147806
by macsddau
Replied by macsddau on topic Latency mesage
Ok value changed to 100000.
I can't check the result, milling machine is not built yet
Wait and see...
Wait and see...
- macsddau
7 years 2 weeks ago - 7 years 2 weeks ago #147821
by macsddau
This affect the max speed.
For this time go back to 50000.
Last edit: 7 years 2 weeks ago by macsddau.
- Leon82
- Thank you received: 79
7 years 2 weeks ago #147825
by Leon82
Replied by Leon82 on topic Latency mesage
You will have to test it out but speed with lost steps is worse than slow rapid speed
- BigJohnT
- Thank you received: 994
7 years 2 weeks ago - 7 years 2 weeks ago #147827
by BigJohnT
Replied by BigJohnT on topic Latency mesage
macsddau
Please update your email to a valid address or stop subscribing to topics. Your subscribing emails are bouncing back with 550 5.5.0 Service refuse.
JT
JT
Last edit: 7 years 2 weeks ago by BigJohnT.
- macsddau@linuxcnc
- Thank you received: 29
7 years 1 week ago #148602
by macsddau@linuxcnc
Replied by macsddau@linuxcnc on topic Latency mesage
Today I run latency test for a from 8 o'clock to 16 o'clock, watching milling videos on YouTube :silly:, reading LinuxCNC documention...
I finally obtain 69358ns max jitter.
I download StepTimingCalculator.ods file and get this result :
In INI file setup this values :
In HAL file setup this values according to Calculator file :
I get the same latency message when I run LinuxCNC.
What's wrong ?
BASE_PERIOD = 70860
*_VELOCITY = 44.10
setp stepgen.x.steplen 1
setp stepgen.x.stepspace 1
setp stepgen.x.dirhold 2
setp stepgen.x.dirsetup 2
What's wrong ?
Time to create page: 0.276 seconds
