Latency mesage SOLVED !
  • macsddau@linuxcnc
  • Premium Member
  • Premium Member
6 years 2 months ago #179011 by macsddau@linuxcnc
Replied by macsddau@linuxcnc on topic Latency mesage
tommylight wrote: uname -a ?J
What PC ?
How much memory ?
Assembled 1U 19" PC:
ASRock J3355B-ITX, 1 G-Skill SO-DIMM 4Gb DDR3L 1333 CL9 RAM, WD GREEN 120Gb SDD, Radeon HD6450 Graphic card
OS :
Linux R883CNC 4.9.0-8-rt-amd64 #1 SMP PREEMPT RT Debian 4.9.110-3+deb9u6 (2018-10-08) x86_64 GNU/Linux
What surprise me is that since I made some change on the settings, Jitter is pretty good for a while, but sometimes I get some inexplicable values.
  • macsddau@linuxcnc
  • Premium Member
  • Premium Member
6 years 2 months ago #179014 by macsddau@linuxcnc
After system update
Linux R883CNC 4.9.0-13-rt-amd64 #1 SMP PREEMPT RT Debian 4.9.228-1 (2020-07-05) x86_64 GNU/Linux
6 years 2 months ago #179028 by tommylight
Replied by tommylight on topic Latency mesage
Did you disable everything regarding power saving, speed step, hyperthreading, etc in BIOS?
Most probably you would get much better latency with RTAI kernel on that board.
  • macsddau@linuxcnc
  • Premium Member
  • Premium Member
6 years 2 months ago #179118 by macsddau@linuxcnc
tommylight wrote: Most probably you would get much better latency with RTAI kernel on that board.
Is this the good link to start with RTAI ?
www.linuxcnc.org/iso/linuxcnc-2.7.14-wheezy.iso
6 years 2 months ago #179124 by tommylight
macsddau@linuxcnc wrote: Is this the good link to start with RTAI ?
Yes, but it is to old so there are no updates or support or well anything, as you can not install anything any more in it.
But if you have a simple machine, please do give it a try, it should work as is and has a much lower latency on older PC's.
6 years 2 months ago #179257 by Todd Zuercher
Replied by Todd Zuercher on topic Latency mesage
If you want to leap through some hoops I think you can still force the old Wheezy version to install some software. You have to update the Debian repos to point to the Debian archives (google it), then fool the computer into thinking the date is before 2020 by setting the computer's date/clock back in time, install the software (using apg-get or synaptic) then reset your date/time correctly. (I think I pulled this off once, but it was a while ago.)
Time to create page: 0.317 seconds
