Reversing direction causes motors to jerk
- Despontene
29 Dec 2019 03:13 #153394
by Despontene
Reversing direction causes motors to jerk was created by Despontene
I'm in the process of putting together a kit from Avid CNC (CNC Router Parts). I got everything setup and working, but one thing is vexing me. The machine runs super smooth as long as it's jogging in one direction, but every time a motor reverses, it jerks in the other direction instead of moving smoothly.
I uninstalled a motor to test on my workbench and got the same behavior. Super smooth rotating in one direction, but reversing direction causes the motor to jump. This happens both when I reverse direction immediately and when I wait a bit between direction changes.
All four motors do exactly the same thing.
I've tried a bunch of different acceleration settings from 1 up to 60 and they all behave the same way.
I've attached my current configuration file.
This is my hardware:
Linux CNC
Nema 34 stepper motors
Gecko GR214V drivers
Mesa 6I25/7I76 I/O cards
Here are a couple of videos where you can hear the CHUNK sound it makes when reversing direction:
vimeo.com/381842213
vimeo.com/381840195
This is how I have the drivers wired to the break out board:
P1 pin 2 (stp) -> 7I76s TB2 pin 3 (step0+)
P1 pin 3 (dir) -> 7I76s TB2 pin 5 (dir0+)
P1 pin 4 (+5v) -> 7I76s TB2 pin 6 (+5vp)
I tried several different timings, but they all behaved the same way. Here are two configurations I tried:
DIRSETUP = 100
DIRHOLD = 600
STEPLEN = 2000
STEPSPACE = 1000
DIRSETUP = 1000
DIRHOLD = 1000
STEPLEN = 4000
STEPSPACE = 3000
Anyone have an idea as to what the problem might be? Thanks in advance : )
Linux CNC
vimeo.com/381842213
vimeo.com/381840195
DIRSETUP = 100
DIRHOLD = 600
STEPLEN = 2000
STEPSPACE = 1000
DIRSETUP = 1000
DIRHOLD = 1000
STEPLEN = 4000
STEPSPACE = 3000
- Leon82
- Thank you received: 79
29 Dec 2019 03:25 #153395
by Leon82
Replied by Leon82 on topic Reversing direction causes motors to jerk
Have you tried a lower acceleration?
It sounds mechanical. Like the acc eleration taking out the backlash
- Despontene
29 Dec 2019 03:39 #153396
by Despontene
Replied by Despontene on topic Reversing direction causes motors to jerk
I’ve tried a bunch of accelerations from 1 to 60 and they all have the same jerk. Maybe I’m setting the acceleration wrong? I’ve been changing the max_accel in the config for each axis.
- Thank you received: 4144
29 Dec 2019 04:16 #153400
Replied by rodw on topic Reversing direction causes motors to jerk
I don't experience a clunk with my plasma cutter with a rack and pinion drive.
I wonder if the clunk is a result of backlash in the spring loaded pinion.
When I started my build, I asked some questions about this on this thread
forum.linuxcnc.org/30-cnc-machines/31509...-loaded-pinion-drive
I don't know if it helps. But I went without a spring loaded pinion based on this thread..
- Despontene
29 Dec 2019 05:12 #153407
by Despontene
Hmm, I suspect it's not a problem with the rack and pinion setup because 1. it happens to all 4 motors, even the Z-axis ball screw, 2. the motors jerk like this even when I run them disconnected from the machine, and 3. they do this no matter how loose or tight the tension is.
- Leon82
29 Dec 2019 05:23 #153408
by Leon82
Is the motor current limiter set correct?
- Despontene
29 Dec 2019 05:26 #153409
by Despontene
When you say "current limiter" are you referring to the Gecko drive or something else?
If you're referring to the drive, then I think I have it setup correctly, but this is my first time using them so I can't be sure.
- Leon82
29 Dec 2019 06:23 #153412
by Leon82
Have you tried it with no backlash value?
- Despontene
29 Dec 2019 07:31 #153417
by Despontene
Yep, I've tried both with and without a backlash value.
29 Dec 2019 08:15 #153419
Time to share your hal and ini files as this is a user fault for sure.
Time to create page: 0.220 seconds
