Reversing direction causes motors to jerk
29 Dec 2019 16:40 #153452 by Despontene
Replied by Despontene on topic Reversing direction causes motors to jerk
Here are my files.
29 Dec 2019 16:43 #153453 by Leon82
Replied by Leon82 on topic Reversing direction causes motors to jerk
Is it normal to have no joint definitions?
29 Dec 2019 16:49 #153456 by Clive S
Replied by Clive S on topic Reversing direction causes motors to jerk
DIRSETUP = 100
DIRHOLD = 600
STEPLEN = 2000
STEPSPACE = 1000
Have you tried setting these to 5000
29 Dec 2019 18:56 #153473 by Despontene
I just tried 5000 for all 4 values. No change,
29 Dec 2019 19:16 - 29 Dec 2019 19:21 #153474 by PCW
Your sample files have backlash enabled. I would definitely set this to 0 while trying other settings (as backlash compensation is guaranteed to make a jerk when reversing)
For timing, I would use
DIRSETUP = 20000
DIRHOLD = 20000
STEPLEN = 5000
STEPSPACE = 5000
As this will work with almost any drive (up to 100 KHz)
just like leaving backlash=0, leave the step/dir timing at this value
until you resolve the jerk-on-reverse issue
Last edit: 29 Dec 2019 19:21 by PCW.
29 Dec 2019 19:21 #153476 by Despontene
I turned off backlash and used your settings PCW. Still no change, but I'll run with this configuration until I get it sorted out. Thanks.
29 Dec 2019 19:27 - 29 Dec 2019 19:28 #153477 by Leon82
You could try the step and dir on the minus posts.
That's how my geckos are wired
Last edit: 29 Dec 2019 19:28 by Leon82.
29 Dec 2019 19:31 #153478 by Despontene
I just tried moving the pins to the minus posts. It reversed the direction of the motors, but otherwise no change.
29 Dec 2019 19:34 #153479 by PCW
Note, just like the backlash and timings, using the minus outputs is necessary
even if it does not impact the issue you have...
29 Dec 2019 19:35 #153480 by Leon82
What is your micro step set to?
Time to create page: 0.588 seconds
