Reversing direction causes motors to jerk
29 Dec 2019 19:35 #153481 by Despontene
Replied by Despontene on topic Reversing direction causes motors to jerk
I've tried everything from 2 micro steps up to 16.
29 Dec 2019 19:47 #153483 by Leon82
Replied by Leon82 on topic Reversing direction causes motors to jerk
Power supply voltage?
29 Dec 2019 19:53 #153484 by rodw
Ok, hold everything for a while. From your original post, you have a gantry machine with 4 motors. please confirm. It looks like you must be using v 2.7.
Its strongly recommended that you upgrade to Master branch (V2.9) or V2.8.
This will give you the ability to run s seperate joint for all 4 motors. So it will mean you will be using a seperate 7i76 stepgen for each side of the gantry with seperate stepper controllers for each motor.
You will also need to install home switches on each side of the gantry. This will let Linuxcnc square the gantry on homing. The homing is quite different under 2.8/2.9 See linuxcnc.org/docs/devel/html/config/ini-homing.html
Run Pncconf again (it will probably have a few more features) reconfigure your machine again and report back.
29 Dec 2019 19:54 #153485 by rodw
x2 what voltage are you running your steppers at?
29 Dec 2019 19:55 #153486 by Despontene
Leon82: Power supply voltage is 48
rodw: Will do. It'll take me a bit, but I'll report back once I'm done.
29 Dec 2019 20:01 #153488 by PCW
I agree the 2.8 is better for gantry machines,
_but_ I really doubt that it will change your
reversing issue, so I think it would be better to understand/solve
that issue first before adding more variables...
29 Dec 2019 20:04 #153489 by Leon82
Some of the Chinese supplies won't put out their rates voltage under load. With 4 34 steppers you may be dropping. My 60 volt wouldn't go over 42 with 2 23 and a 34 on it.(while idle)
29 Dec 2019 20:08 #153490 by Despontene
I'm using the Avid power supply with their motors, so I assume that's not the problem. I have measured the voltage at the Geckos between 46-48 depending on load. This also happens when I only have a single motor hooked up.
29 Dec 2019 20:22 #153493 by PCW
Is it possible you are going into step drive standby at reversals?
You might try disabling this feature (set the standby current to 100%)
29 Dec 2019 20:27 #153495 by Despontene
Just tried disabling standby and it didn't help. Good idea though.
Time to create page: 0.706 seconds
