What alternatives to gantrykins?
- Thank you received: 4652
Could not open command file 'gan_xxyz.hal'
So there is a file referenced in your INI which does not exist in your config folder.
- captain chaos
- Thank you received: 3
set the little old grey cells in motion, I remembered I posted my config way back so I went to my profile > Attachment Manager > #4 My Zip.Zip. - U Axis Configuration, had all my original files how lucky.
I simply took my old config folder (gan_xxyz ) dumped it in the configs folder created a shortcut to it with
CNC > Linux CNC > Linux CNC Configuration Selector
Ticked the create short cut box > hit OK
Now all I need to do is configure the Parallel Port
Thanks again
- captain chaos
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/linuxcnc/hal_parport.ko': -1 Resource temporarily unavailable
gan_xxyz.hal:13: exit value: 1
gan_xxyz.hal:13: insmod failed, returned -1
See the output of 'dmesg' for more information.
1510
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
I then did parport test
paul@paul-desktop:~$ halrun -I -f ptest.hal
ptest.hal:1: exit value: 1
ptest.hal:1: insmod failed, returned -1
halcmd:
The dmesg came back with
[ 115.260759] config string '0x378 out '
[ 115.260788] PARPORT: ERROR: port parport0 claim failed
So it seems to me that the file can't be found as it needs to find the parport first
The hal comand is
loadrt probe_parport
loadrt hal_parport cfg="0x378 out "
setp parport.0.reset-time 1000
loadrt stepgen step_type=0,0,0,0
loadrt charge_pump
net estop-out charge-pump.enable iocontrol.0.user-enable-out
net charge-pump <= charge-pump.out
loadrt pwmgen output_type=0
Do I reconfigure the parallel port to cfg="0x378 out" and if so could you point me in the direction of how this is done.
Or do I change the halfile to read the actual port and if so how do I find this.
Thanks Paul
- captain chaos
Cheers Paul
- captain chaos
I have :-
Debian GNU / Linux, with linux 3.4-9-rati -686- pae
Grub Version 1.99-27+ deb7u3
and Linux cnc 2.8
Replied by captain chaos on topic Stepper enable?
I can't seem to get the Charge pump to work
Is "External Enable" Estop in or Digital in 0 (Digital in has 0,1,2 and 3)
Break out Board Pin Assignments and Step Conf images included
I'm using step config XY,UV foam to build a 4 joint XXYZ gantry router
Next question would be how do I split XY, UV to be X linked to joint U as it is and split V from Y to make it V=Z
This looks like a long hard slog, so should maybe move the topic to something like "Par Port Stepper Gantry XXYZ"
Chers Paul
Additionally to the above I tried to set up the parallel port tester and got the following error :-
chaos@gantry:~/Desktop$ halrun -I -f ptest.hal
halrun: Realtime already running. Use 'halrun -U' to stop existing realtime session.
chaos@gantry:~/Desktop$ halrun -U
Could not open command file 'ptest.hal'
halcmd: exit
halcmd: exit
RTAPI: ERROR: could not open shared memory (No such file or directory)
ERROR: rtapi init failed
HALCMD: Release Mutex failed!
HAL: ERROR: could not initialize RTAPI
halcmd: hal_init() failed: -22
NOTE: 'rtapi' kernel module must be loaded
Error: Module hal_lib is not currently loaded
Error: Module rtapi is not currently loaded
Error: Module rtai_math is not currently loaded
Error: Module rtai_sched is not currently loaded
Error: Module rtai_hal is not currently loaded
Looks like I need to load the 'rtapi' kernel as opposed to the 3.4-9-rati that I have
if so how do I go about this
can anyone point me in the right direction please
Cheers Paul
- Thank you received: 7468
Sample configurations>apps>parport>parport_0x378
- captain chaos
Sorry been all over the been all over the show looking for a command
but can't find out how to start linuxcnc in terminal.
Cheers Paul
type
linuxcnc
enter
- captain chaos
$ where is linuxcnc
S /usr/bin/linuxcnc
comes up with :- Linux CNC config selector gui
went to
ticked create desktop shortcut clicked on OK and got port tester gui
but where should I paste "and paste the error/debug info ?"
and are you referring to:-
Thanks Paul
- captain chaos
10, 11, 12, 13 and 15 are inputs and are all green
all Parallel Port Signals are to be active high
does the red indicator indicate indicate active high or low
or do they indicate in or out
thanks Paul
