Cnc Help stepper timing and max velocity
- Leon82
- Thank you received: 79
25 Jan 2020 22:58 #155765
by Leon82
Replied by Leon82 on topic Cnc Help
I make a test config along with my main to play around and transfer into the main
The following user(s) said Thank You: Unique_cnc
- Unique_cnc
26 Jan 2020 04:10 #155775
by Unique_cnc
Replied by Unique_cnc on topic Cnc Help
ok thanks..so then my next question is how do I increase the actual speed/velocity of my machine? in stepconfig it has a theoretical velocity of say 42...but anything above say 21 has no effect?
- Mike_Eitel
- Thank you received: 183
26 Jan 2020 11:00 #155782
by Mike_Eitel
Replied by Mike_Eitel on topic Cnc Help
Is everyting nice and stable, repetitive until 21 now?
- Leon82
26 Jan 2020 12:29 #155797
by Leon82
Check for the max velocity in the ini files.
There are several.
Velocity is limited by you max attainable stepnrate also
There are several.
- bbsr_5a
- Thank you received: 106
26 Jan 2020 13:01 #155803
by bbsr_5a
Replied by bbsr_5a on topic Cnc Help stepper timing and max velocity
most likly
[TRAJ]
MAX_LINEAR_VELOCITY = 21
DONT forget to get the StepGEN_ACC to a Recent settings
you want good Acceleration not reatching the Top speed at 10mm Cut Distance
[TRAJ]
- Unique_cnc
26 Jan 2020 20:20 #155843
by Unique_cnc
yeah it seems pretty good..would just like some faster jog speed..and if i ever get around to adding plasma...would need faster speed...
- Unique_cnc
26 Jan 2020 20:28 #155845
by Unique_cnc
I did try edit this and it was like 21.374884 (but all it seemed to do is up the theoretical velocity..ie I can select higher speed when testimg axis,but it doesnt actually go any higher..ie from 21 to 40 is the same speed.)
so the velocity is obviously a result of an equation? do you know what the equation is? or what stepconfig does to work that out?
There are several.
- Unique_cnc
26 Jan 2020 20:34 #155846
by Unique_cnc
yeah i tried editing that..but like i said in my reply to Leon82 editing that only seems to give me theoretical increase..it is still limited to 21.blah blah(i cant remember what the actual numbers are.)
Replied by Unique_cnc on topic Cnc Help stepper timing and max velocity
most likly
[TRAJ]
- Thank you received: 7468
26 Jan 2020 21:45 #155861
Replied by tommylight on topic Cnc Help stepper timing and max velocity
There are entries for max_velocity in the Display, Traj, and each axis sections.
- Leon82
26 Jan 2020 21:53 #155862
by Leon82
Replied by Leon82 on topic Cnc Help stepper timing and max velocity
When testing an axis in stepconf it won't let you go higher than the steprate it has determined by your settings.
You would have to lower the drive timings, which could introduce following errors
Time to create page: 0.261 seconds
