LinuxCNC 2.8 DM542T drivers Mesa 7i96 controller
10 Feb 2020 22:29 #157011 by J Crowder
Replied by J Crowder on topic LinuxCNC 2.8 DM542T drivers Mesa 7i96 controller
One more question: How do I get the 2nd motor on the gantry to work? I added it as the Y2 driver but it did not come up to tune. I have everything in pieces at the moment since I am trying to get things moved out to the shop so it will be a minute before I can test anything. I do have the PC inside still so I can change settings to be prepared to test later. Once I get it all out in the shed I plan to have all of the motors disconnected from the screws and run the motors to make sure they are all working as they should.
  • Moderator
  • Moderator
11 Feb 2020 04:02 #157035 by tommylight
Replied by tommylight on topic LinuxCNC 2.8 DM542T drivers Mesa 7i96 controller
Have a search on the forum, there are several configs using 7i96 and 2 motors on the same axis, compare them to yours.
The following user(s) said Thank You: J Crowder
18 Feb 2020 21:57 #157810 by J Crowder
I finally got it working with Debian Stretch and LinuxCNC 2.9. I used pncconf and the tandem axis option for my second Y motor. Thanks for everyone's help. I will be talking to you as soon as I get the motors mounted and get my router going.
08 Apr 2020 11:50 #163215 by kbec
I believe I have the same setup mentioned here. Do I need a fan?
I have a 5v 1.0 A samsung phone charger I was going to use to power the board.
I have this power supply, ALITOVE 36V 10A 360W Power Supply Switch Transformer Adapter AC 110V / 220V to DC 36V 10amp Universal Regulated Switching Converter for LED Strip Light CCTV Camera Security System with 3 36v outputs.
and three of these: STEPPERONLINE CNC Stepper Motor Driver 1.0-4.2A 20-50VDC 1/128 Micro-step Resolutions for Nema 17 and 23 Stepper Motor
I think with that I can drive 3 motors and the board. I am not sure about driving a fan though. How much heat do the motor drivers make when they are powered up?
  • Moderator
  • Moderator
08 Apr 2020 12:26 #163218 by tommylight
Not much, and i never needed a fan to cool them.
Time to create page: 0.573 seconds
