Problem connecting hy_vfd via RS485
  • strahlensauger
  • strahlensauger's Avatar Topic Author
  • Elite Member
  • Elite Member
23 Mar 2020 19:58 #161263 by strahlensauger
Problem connecting hy_vfd via RS485 was created by strahlensauger
I am setting up a cnc mill and connected it to Linuxcnc. I found solutions to all my Problems here in the forum,
but now I'm stuck.
Yesterday I tried to connect my vfd to an RS485USB Dongle and I could start the spindle with these commands
sudo chown 666 /dev/ttyUSB0
halrun
loadusr -Wn hy_vfd hy_vfd -n hy_vfd -d /dev/ttyUSB0 -p none -r 19200 -s 1
show pin
setp hy_vfd.enable 1
setp hy_vfd.speed-command 12000
setp hy_vfd.spindle-forward 1
setp hy_vfd.spindle-on 1
I put in some commands in my hal file to start the spindle, but it didn't want to do a single turn.
I thought that I didn't have enough rights and copied the config files to the root account and
started the spindle via the above halrun commands with root rights and it worked, but linuxnc didn't start with a
"Refusing to run as root without fallback UID specified". So I logged back into my user account trying to
start the spindle again via halrun, but now it even starts there, giving back a:
open: Permission denied
ERROR Can't open the device /dev/ttyUSB0 (errno 13)
hy_vfd: ERROR: couldn't open serial device
<stdin>:3: waitpid failed hy_vfd hy_vfd
<stdin>:3: hy_vfd exited without becoming ready
halcmd: Note: Using POSIX realtime
a su does turn the spindle.
Linuxcnc doesn't start anymore, the serial /dev/ttyUSB0 could not be opened.
I would really appreciate it if somebody could give me a hint.
Attachment not found
  • Moderator
  • Moderator
23 Mar 2020 20:03 #161264 by tommylight
Replied by tommylight on topic Problem connecting hy_vfd via RS485
Not sure, but search for arduino usb permission denied, there is a line that add the user to the dialout group.
  • strahlensauger
  • Elite Member
  • Elite Member
23 Mar 2020 20:19 #161270 by strahlensauger
Replied by strahlensauger on topic Problem connecting hy_vfd via RS485
That was quick and it worked as the halrun is concerned, thanks a lot.
Still the problem that the spindle doesn't turn in the linuxcnc Gui.
  • Moderator
  • Moderator
23 Mar 2020 20:26 #161272 by tommylight
Oh good, that was just a stab in the dark, from the time i built something with an arduino.
The following user(s) said Thank You: strahlensauger
23 Mar 2020 20:27 - 23 Mar 2020 20:28 #161273 by MovT
Replied by MovT on topic Problem connecting hy_vfd via RS485
Do you have made a udev rule for the USB device? Can halp but must not.
Last edit: 23 Mar 2020 20:28 by MovT.
  • strahlensauger
  • Elite Member
  • Elite Member
23 Mar 2020 23:14 #161297 by strahlensauger
It seems the dialout group was the Problem. Now I can start at least the spindle.
It still doesn't react to M3 or M5, but I think I have to configure that in the hal file.
  • strahlensauger
  • Elite Member
  • Elite Member
26 Mar 2020 20:23 #161612 by strahlensauger
Now the spindle is working almost as I wish.
There is still one thing I didn't find out.
The speed goes from 11520 reverse to 11520 forward.
Is there a possibility to go to 24000? I think the Huanyang spindle can
do that.
The manual is quite technical for a non-engineer...
  • Moderator
  • Moderator
26 Mar 2020 22:26 #161620 by tommylight
Attach hal and ini files.
  • strahlensauger
  • Elite Member
  • Elite Member
26 Mar 2020 22:53 #161625 by strahlensauger
Here they are
  • Moderator
  • Moderator
26 Mar 2020 23:02 #161627 by tommylight
I could not notice anything wrong regarding spindle, you could just replace the 5000 values with 24000 so you get better scaling, but it looks like that is not being used here.
Time to create page: 0.200 seconds
