2 seperate MPG handwheels for each axis - CNC Lathe build
- denhen89
- Thank you received: 27
17 May 2020 11:42 #168044
by denhen89
Replied by denhen89 on topic 2 seperate MPG handwheels for each axis - CNC Lathe build
@Rodw: Of course i understand to find out a lot of things by my self, but i really tried but its difficult for me.
Thanks for "setp axis.x.jog-scale 1", but if in Halmeter nothing happens when turning the handwheel, then i think that the problem might be in the wiring, or am i wrong ?
- Thank you received: 4137
17 May 2020 11:53 #168045
Replied by rodw on topic 2 seperate MPG handwheels for each axis - CNC Lathe build
Can you chexk what I used here
I have a feeling I might have been different.
If the mode is right and it is not counting, then look at wiring.
sserial_port_0=200xxxxI have a feeling I might have been different.
- denhen89
17 May 2020 12:07 #168046
by denhen89
I have tried: sserial_port_0=200xxxx
nothing happens on halmeter.
- Thank you received: 7461
17 May 2020 12:11 - 17 May 2020 12:36 #168047
Replied by tommylight on topic 2 seperate MPG handwheels for each axis - CNC Lathe build
The wiring is OK, on TB5.
Edited, wrong info removed.
Last edit: 17 May 2020 12:36 by tommylight. Reason: wrong info
17 May 2020 12:13 #168048
The blue and white wire.
- denhen89
17 May 2020 12:16 #168049
by denhen89
Okay, i will test it, but on this manual: wiki.eusurplus.com/downloads/7i76E.pdf
on page: Connection of MPG's, it shows that i should connect it to TB5
- denhen89
17 May 2020 12:27 #168050
by denhen89
Still not showing anything on Halmeter
17 May 2020 12:30 #168051
Back in a few.
Yes it does, leme check again.Okay, i will test it, but on this manual: wiki.eusurplus.com/downloads/7i76E.pdf
Back in a few.
17 May 2020 12:35 #168052
Yes they should be on TB5, my bad, was thinking of analog inputs somehow.
Can you also check encoder.1 with hal meter ?
- denhen89
17 May 2020 12:37 - 17 May 2020 12:37 #168053
by denhen89
Works!
What i did. I took the second MPG handwheel i had lying around and connected all 4 wires to the terminals but without the resistors. Halmeter shows counts!
EDIT: and of course i changed the white and blue wire back to TB5
Last edit: 17 May 2020 12:37 by denhen89.
Time to create page: 0.463 seconds
