What am I doing wrong?
  • JayDeeTOL
  • JayDeeTOL's Avatar Topic Author
  • Junior Member
  • Junior Member
31 May 2020 22:22 #169582 by JayDeeTOL
What am I doing wrong? was created by JayDeeTOL
I have linux mint 19.3 and trying to install cnc from this page of directions and when I get to the highlighted portion my terminal does this.
Note, selecting 'libghc-parsers-dev:i386' instead of 'libghc-parsers-dev-0.12.8-34bbe:i386'
Note, selecting 'libghc-parsers-prof:i386' instead of 'libghc-parsers-prof-0.12.8-34bbe:i386'
Note, selecting 'libghc-pipes-parse-dev:i386' instead of 'libghc-pipes-parse-dev-3.0.8-2983e:i386'
Note, selecting 'libghc-pipes-parse-prof:i386' instead of 'libghc-pipes-parse-prof-3.0.8-2983e:i386'
Note, selecting 'libghc-pipes-zlib-dev:i386' instead of 'libghc-pipes-zlib-dev-0.4.4.1-7a278:i386'
Note, selecting 'libghc-pipes-zlib-prof:i386' instead of 'libghc-pipes-zlib-prof-0.4.4.1-7a278:i386'
Note, selecting 'libghc-swish-dev:i386' instead of 'libghc-swish-dev-0.9.1.10-5218e:i386'
Note, selecting 'libghc-swish-prof:i386' instead of 'libghc-swish-prof-0.9.1.10-5218e:i386'
Note, selecting 'libghc-these-dev:i386' instead of 'libghc-these-dev-0.7.3-43248:i386'
Note, selecting 'libghc-these-prof:i386' instead of 'libghc-these-prof-0.7.3-43248:i386'
E: Unable to locate package checkout
oem@cnc:~$
  • Moderator
  • Moderator
31 May 2020 23:27 #169591 by tommylight
Replied by tommylight on topic What am I doing wrong?
Did you do a
sudo apt update
before trying to install ?
And you are using a 32 bit version of Linux Mint, while almost everything here and on the net is on 64 bit version, to the point that neither Ubuntu nor Mint will release it any more.
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
01 Jun 2020 01:27 #169602 by BeagleBrainz
Replied by BeagleBrainz on topic What am I doing wrong?
It's a shame you're taking the long way round, when there are pre made packages for Mint, 64 Bit only, or a 64 bit Mint ISO with Linuxcnc installed.
01 Jun 2020 11:02 #169646 by 0x2102
Replied by 0x2102 on topic What am I doing wrong?
I am running Linux Mint as well and you can just follow this link
www.gnipsel.com/linuxcnc/uspace/debian9-emc.html
Select the version you want 2.7, 2.8 or master.
  • JayDeeTOL
  • Junior Member
  • Junior Member
01 Jun 2020 11:56 #169657 by JayDeeTOL
Replied by JayDeeTOL on topic What am I doing wrong?
I'm sorry. I spoke to another person and now I have installed 2.7.14. Now my problem is the ethernet connection. I have wireless, but I am trying to install the mesa 7i92.
  • JayDeeTOL
  • Junior Member
  • Junior Member
01 Jun 2020 11:56 #169658 by JayDeeTOL
Im back at cnc 2.7.14
  • BeagleBrainz
  • Visitor
  • Visitor
01 Jun 2020 13:25 #169664 by BeagleBrainz
Easiest Mint Install:
forum.linuxcnc.org/9-installing-linuxcnc...aver-mint-iso#165631
What IP range are you using for your wireless & Ethernet (wired) connections.
  • JayDeeTOL
  • Junior Member
  • Junior Member
01 Jun 2020 13:46 #169666 by JayDeeTOL
I am using wifi. My ethernet port says device not managed.
  • JayDeeTOL
  • Junior Member
  • Junior Member
01 Jun 2020 13:47 #169667 by JayDeeTOL
GNU nano 2.7.4 File: /etc/network/interfaces
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
source /etc/network/interfaces.d/*
# The loopback network interface
auto lo
iface lo inet loopback
[ Read 8 lines ]
^G Get Help ^O Write Out ^W Where Is ^K Cut Text ^J Justify ^C Cur Pos
^X Exit ^R Read File ^\ Replace ^U Uncut Text^T To Spell ^_ Go To Line
  • Moderator
  • Moderator
01 Jun 2020 14:17 #169669 by tommylight
If you want to use the ethernet exlusively for Mesa, foloow this tutorial:
linuxcnc.org/docs/html/man/man9/hm2_eth.9.html
If you need to change it , follow this:
forum.linuxcnc.org/27-driver-boards/3559...ethernet-mesa-boards
Recommanded to set the Mesa board to use the 10.10.10.10 address, and edit the IP address on the computer accordingly.
Time to create page: 0.153 seconds
