BDI EMC software
- Thank you received: 7504
09 Jun 2020 15:13 #170860
Replied by tommylight on topic BDI EMC software
Try inverting the enable pin in hal or in stepconf, usually named amplifier enable in stepconf, machine-is-on or xenable in the hal file.
- TglEMC
- Thank you received: 4
09 Jun 2020 15:46 - 09 Jun 2020 15:51 #170867
by TglEMC
Replied by TglEMC on topic BDI EMC software
No joy. I also tried inverting one of the axis pins.
I also noticed that inverting parport does not invert the net xenable.
Last edit: 09 Jun 2020 15:51 by TglEMC.
09 Jun 2020 15:55 #170870
Can you upload the hal and ini files as they are now.
I can not recall anything else that would cause such behaviour.
09 Jun 2020 15:56 #170871
Check if you can move the motor by hand before enabling LinuxCNC and after enabling it.
- TglEMC
09 Jun 2020 16:04 #170874
by TglEMC
Yes, I can move the motors with the power off but when the controller is on the are locked from the controller being powered. The stepconf axis test increments the motors so I know they are good.
I can upload anything you would like, just tell me where.
09 Jun 2020 16:14 #170878
You can upload hal and ini and zip files here on the forum, under the editor, attachments button.
- TglEMC
09 Jun 2020 16:35 #170880
by TglEMC
Renamed the files to tglEMC.
09 Jun 2020 16:57 #170884
The files are OK for the most part, so they should work. So:
setp stepgen.0.steplen 1
setp stepgen.0.stepspace 0
setp stepgen.0.dirhold 35000
setp stepgen.0.dirsetup 35000
Now, can you test moving the motors when they are powered, start LinuxCNC and check if they can be turned, then press F1 and F2 and check again if they can be moved.
- TglEMC
09 Jun 2020 18:15 #170888
by TglEMC
I reset the inverted pin. Looking at, and playing with controls I did get an axis to increment one time, same as it did with stepconf even though I have it set to continuous feed. It seems that it is accessing the motors, just with not the correct control. It does show "no tool" but that should not matter. Other than that I cannot get it to feed continuously.
Tomorrow I will play with setting up a gcode file to see if it can run it. I cannot help thinking that there is something I'm missing in the set up.
- Mike_Eitel
- Thank you received: 183
10 Jun 2020 11:14 #170973
by Mike_Eitel
Replied by Mike_Eitel on topic BDI EMC software
Hi
1. Have you changed as tommy proposed
setp stepgen.0.steplen 1 i'm unsure but would try 5000 or 10000
setp stepgen.0.stepspace 1 i'm unsure but would try 5000 or 10000
setp stepgen.0.dirhold 148500 here would use 20000
setp stepgen.0.dirsetup 148500 here would use 20000
I'm unsure if in parport 1 is ok. In other an impuls of 1 microsecond will never pas a bob. The last two times are for direction time and 0.145 seonds is realy slow.
2.
To make it easy strip of the enable cable. With a cable connectd to gnd or logic-supply voltage you should be able to switch the motors from movable to blocked by current.
If you are not able to do this, you probably need some watchdog cycling. If so come back to us.
3.
If you know your motors are enabled, there could be that you have crossed direction and puls.
Good luck
Mike
2.
3.
Good luck
Mike
Time to create page: 0.274 seconds
