Arc Starts, Arc OK good, No motion
- phillc54
- Thank you received: 2100
20 Jun 2020 00:30 #172130
by phillc54
Replied by phillc54 on topic Arc Starts, Arc OK good, No motion
Could you still check with Halshow as Rod suggested, as spindle.0.at-speed not being True will cause the issue you describe.Thanks for the reply. I was just looking into this and you are correct, my HAL does not have any of the spindle vars.
- dave4606
20 Jun 2020 00:35 #172131
by dave4606
Replied by dave4606 on topic Arc Starts, Arc OK good, No motion
Spindle.0.at-speed is True at all times.
- phillc54
20 Jun 2020 00:40 #172132
by phillc54
And the Arc OK LED on the GUI turns definitely turns on?
- dave4606
20 Jun 2020 00:41 #172133
by dave4606
Yep, 100%.
I get Orange Torch ON, then Green Arc OK, then no movement.
- phillc54
20 Jun 2020 00:42 #172134
by phillc54
Can you compress you config directory and post it.
- dave4606
20 Jun 2020 00:44 - 20 Jun 2020 00:52 #172135
by dave4606
EDIT: I take that back. Tried making a new design with the included extras tab after that run and its doing the same arc start no movement thing again.
Scratch that. Did a computer and mainboard power cycle and it working as it should now.
No other changes. Not sure what happened but its working. Thanks everyone for the input!
Last edit: 20 Jun 2020 00:52 by dave4606.
- dave4606
20 Jun 2020 01:21 #172136
by dave4606
I think my issue is coming down to the realtime flag. When im running Mozilla looking at this forum it will exhibit the behavior im seeing, it finally threw a watchdog flag also.
with mozilla closed it seems to be working fine.
- phillc54
20 Jun 2020 01:32 #172137
by phillc54
Have you done a thorough latency-histogram test.
Something here may help. www.forum.linuxcnc.org/plasmac/39317-watchdog-has-bit#171364
latency-histogram --nobase --sbinsize 1000Something here may help. www.forum.linuxcnc.org/plasmac/39317-watchdog-has-bit#171364
The following user(s) said Thank You: dave4606
- dave4606
21 Jun 2020 16:42 #172255
by dave4606
Thanks for the link. Looks like my Eth card doesnt support IRQ Coalescing, might need to get a new PCI card. Anyone have one they recommend?
david@dave4606:~$ sudo ethtool -c eth1
Coalesce parameters for eth1:
Cannot get device coalesce settings: Operation not supported
-Dave
-Dave
- Thank you received: 5321
21 Jun 2020 19:03 #172268
Replied by PCW on topic Arc Starts, Arc OK good, No motion
If its not supported, its probably OK
What CPU and Motherboard do you have?
Do you have all power management and C states > C1 disabled? (in the BIOS)
Do you have idle=poll in the kernel command line?
Time to create page: 0.224 seconds
