- LinuxCNC
- General LinuxCNC Questions
- How would you design a real time application for cnc control in c / c++ ???
- Grotius
- Thank you received: 2349
05 May 2021 03:16 #207924
by Grotius
Replied by Grotius on topic How would you design a real time application for cnc control in c / c++ ???
Your errors are mostly typo's.
A "int" in not of type "pos".
When you take your time, you can solve this. And try to code as simple as possible.
Try to use only the std:: lib function's instead of using qt libs. Only use qt lib's if there are no other solutions.
- udoS
- Thank you received: 25
14 May 2021 16:00 - 14 May 2021 23:02 #208814
by udoS
Replied by udoS on topic How would you design a real time application for cnc control in c / c++ ???
Hi Grotius
This call is made periodically to update the values in the HMI.
______________________________________________________
void update_status(){ //function used in display/display.h
const char *cstr = nmlfile.c_str();
RCS_STAT_CHANNEL *stat = new RCS_STAT_CHANNEL(emcFormat, "emcStatus", "xemc", cstr);
___________________________________________________________________________________
So every call you open a NEW channel. I don't see a "close" or "cleanup " or something like that.
I have a 'little' request.
Could you supply a very basic sample in Qt or other c++ app showing the initialisation and communication with linuxcnc over nml. I just don't get it extracted from your Qt_c++_hmi.
Specific: the shared mem semaphore part.
Best Regards
udo
Best Regards
udo
Last edit: 14 May 2021 23:02 by udoS.
- Grotius
17 May 2021 11:51 #209217
by Grotius
That's correct. During code reverse engineering there is not been added something to close or cleanup the
channel. It's a while ago.
I think on my github channel there is some info about that. link
About nml i have no more info. I did not use it, or extended the code after above example was made.
- TheRoslyak
- Thank you received: 37
31 May 2021 09:42 - 01 Jun 2021 09:16 #210783
by TheRoslyak
Replied by TheRoslyak on topic How would you design a real time application for cnc control in c / c++ ???
Hi grotius
Can you check project? Problem is same - I include "opencascade.h" in Robot.h and project is crash
dropmefiles.com/VUTzL
Last edit: 01 Jun 2021 09:16 by TheRoslyak.
- Grotius
05 Jun 2021 14:45 #211218
by Grotius
Opencascade must be included in the mainwindow.h file, just as the example does.
You can not include opencascade several times. It will trow error's.
- TheRoslyak
09 Jun 2021 08:52 - 09 Jun 2021 08:54 #211599
by TheRoslyak
Hi
My Robot.h is your mainwindow.h
I do this but it didn’t work.
Last edit: 09 Jun 2021 08:54 by TheRoslyak.
- Joco
- Thank you received: 327
09 Jun 2021 09:45 #211603
by Joco
Replied by Joco on topic How would you design a real time application for cnc control in c / c++ ???
When you say "throws errors" are you referring to compile or running?
I have working code that includes opencascade.h multiple times other files need to reference the definitions. So I know that side of things works. Although you may need to be careful on the order of inclusion. I seem to recall that mattered.
If you are getting run time errors then that is a different kettle of fish.
- TheRoslyak
09 Jun 2021 10:02 #211606
by TheRoslyak
Error when compile (Build)
- Grotius
09 Jun 2021 10:38 #211609
by Grotius
I checked the project. It works. The robot loads. To my surpise he actually uses the qml interface.
I had to set some includepaths. This is because he has a different linux version.
For the rest the code look fine. It's nice too to see code modified by other users.
Warning: Spoiler!
# lcnc
INCLUDEPATH += /usr/lib/ \
/opt/lib/linuxcnc/modules/ \
/opt/include/ \
/usr/include/linuxcnc/
#Hal
INCLUDEPATH+= /opt/linuxcnc/include/ \
/opt/linuxcnc/src/hal/ \
LIBS+= -L/opt/linuxcnc/lib/
LIBS+= -llinuxcnchal
#Opencascade
LIBS+= -L/usr/local/lib/ \
INCLUDEPATH += /usr/local/include/kdl/ \
/usr/local/include/opencascade/ \
/usr/include/eigen3/ \
/usr/include/ \
/usr/local/lib/ \For the rest the code look fine. It's nice too to see code modified by other users.
- TheRoslyak
09 Jun 2021 11:05 - 09 Jun 2021 11:09 #211612
by TheRoslyak
Honestly, I don't understand what has changed
Error appears if I uncommentin Robot.h
I want to connect slider to 3d model, but this string crash all compile
PS. I have been working on the design of the project so far
Can you check forum.linuxcnc.org/38-general-linuxcnc-q...elerations?start=150 topic
#include <opencascade.h>I want to connect slider to 3d model, but this string crash all compile
Last edit: 09 Jun 2021 11:09 by TheRoslyak.
- LinuxCNC
Time to create page: 0.160 seconds
