- LinuxCNC
- General LinuxCNC Questions
- How would you design a real time application for cnc control in c / c++ ???
- Grotius
- Thank you received: 2349
23 Aug 2021 14:24 - 23 Aug 2021 14:26 #218520
by Grotius
Replied by Grotius on topic How would you design a real time application for cnc control in c / c++ ???
Ok. We can talk with the plc from within qt. Why do you need nml?
Edit, ok i see your github is online.
Last edit: 23 Aug 2021 14:26 by Grotius.
- udoS
- Thank you received: 25
23 Aug 2021 16:14 #218523
by udoS
Replied by udoS on topic How would you design a real time application for cnc control in c / c++ ???
Hi Grotius,
I did install a fresh linux-pro.
Now how to get the linuxcnc-dev and the qtcreator. utmost priority. And if possible for now nothing else.
- udoS
23 Aug 2021 16:17 #218524
by udoS
Because now the plc is talking to the HAL and the HAL to the cnc.
Using nml in the PlugIn I could talk to the cnc directly.
- Grotius
23 Aug 2021 16:32 - 23 Aug 2021 16:33 #218525
by Grotius
In menu bar, 3rd from below : skynet software installer. Takes a few minutes.
When using lcnc i understand this route.
Last edit: 23 Aug 2021 16:33 by Grotius.
- udoS
23 Aug 2021 16:39 #218526
by udoS
nop
terminal pops up asking for sudo pw
terminal closes very fast after something I can't read. Too fast. Nothing then.
- Grotius
23 Aug 2021 16:42 - 23 Aug 2021 16:43 #218528
by Grotius
Read:
sourceforge.net/projects/linux-11-pro/
Then you see : passwrd : user
It also say's : sudo su
Then type passwd.
Then type passwd.
Last edit: 23 Aug 2021 16:43 by Grotius.
The following user(s) said Thank You: bkt
- bkt
- Thank you received: 114
27 Dec 2021 18:33 #230074
by bkt
Replied by bkt on topic How would you design a real time application for cnc control in c / c++ ???
Hey Grotius .... not read well but is a ready gui Qt5 c++ for linuxcnc ethercat? You are the best one. (the link is for a ISO, but think there are QT project too inside and we can copy and paste to other pc...)
Is possible to copy that QT project and just running in a pc with mint 19 and ethercat? .... there are some special observation for run project?
Regards
BKT
Regards
BKT
- Grotius
28 Dec 2021 06:00 - 28 Dec 2021 06:03 #230120
by Grotius
This is a installer : github.com/grotius-cnc/Linux-Pro/release...0.0/online-installer
It will install qt, ethercat etc on whatever linux distro.
For qt projects, visit my github. What are you looking for?
This project was tested on ethercat + qt :
github.com/grotius-cnc/skynet_robot_cont...kynet_Project.tar.gz
Last edit: 28 Dec 2021 06:03 by Grotius.
- bkt
28 Dec 2021 21:24 - 28 Dec 2021 21:31 #230175
by bkt
Simply try to build a multipourpose gui for robot and smart plc system (classic ladder) based on ethercat and linuxcnc ....i need it but i've so little time for make it ....
and how about hal_core? seems a good base for my project. It have some problem with nml or other library?
thanks again
thanks again
Last edit: 28 Dec 2021 21:31 by bkt.
- Grotius
29 Dec 2021 12:01 #230214
by Grotius
Hi Bkt,
Option 1:
My older github examples are made with a lcnc rip beside it. Maybe this is something for you to start with.
At that time my knowlegde stopped by using a lcnc rip beside qt.
The example's show to interact between qt c++ and lcnc. It also shows how to setup a component within the qt gui that
run's on the qt thread. This is usable for making a simple gui. Just like axis, gmocappy, gscreen etc.
They all run at a slow rate, ~ 0.1 sec.
In above example's nml is inside the lcnc rip and can be accesed by qt directly on the c++ level. There are example's
how to send and read commands to and from the nml server.
Option 2:
Hal-core is only using the hal environment of the original lcnc code. It is clean from Python, Nml, etc.
It has no smoke curtains like halcompile under the hood. It uses gcc and g++ commands to compile.
All lcnc components will work in hal-core.
Hal-core uses high level c++ library's from kernel space.
If you exactly know what you want to code, you can code it straight away in hal-core.
It takes some coding knowlegde.
If you start at Option.1 you can later on expand your knowlegde by using hal-core.
Option 1:
Option 2:
- LinuxCNC
Time to create page: 0.210 seconds
