I can't install nvidia 173.14 (Geforce FX5200) driver on Debian 9 Stretch
20 Aug 2020 22:06 #178881 by Himarc3D
en.m.wikipedia.org/wiki/Pentium_4
Not all Pentium 4 are 64.
community.intel.com/t5/Processors/How-to...ocessors/td-p/412460
The error message you got is telling you the system you have is 32 bit and you trying install 64 bit package.
The following user(s) said Thank You: aparecido
20 Aug 2020 23:06 #178883 by aparecido
Yes, it presented the error because the package is 64 bits and the system is 32 bits.
I checked my Pentium 4 model and unfortunately it is not 64Bits.
Thank you
24 Aug 2020 16:50 #179255 by aparecido
How do I update linuxcnc via repository or package, from ISO ubuntu-10.04-linuxcnc3-i386 already installed?
Will you have any problems updating using a .DEB package? I did the test with this iso that has the Kernel RTAI, the Jitter is at most in 20000.
Unfortunately with Debian, I can't get a suitable jitter.
25 Aug 2020 19:30 #179434 by aparecido
I'm continuing the tests with the FX5200, for now, it only worked on Ubuntu.
A friend lent me an IPM31 v1.03 (Pcware / Pegatron) card with a core2duo E7500 2.93GHz-FSB 1066Mhz-L2 cache 3MB, with a 1GB Kingston DDR2, hd sata, with onboard video.
I tried with ISO Debian Stretch using the settings recommended here on the forum, to disable a processor core. Jitter is at a good value, but at some point it jumps to over 100000ns.
I tried to install the Debian ISO 10.5.0 and install the RTAI kernel using this tutorial and packages (attached in the tutorial), but it returns these errors to me:
#sudo dpkg --install linux-image-4.14.132-rtai-amd64_4.14.132-rtai-amd64-1_amd64.deb
update-initramfs: Generating /boot/initrd.img-4.14.132-rtai-amd64
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8107e-2.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8107e-1.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168h-2.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168h-1.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168g-3.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168g-2.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8106e-2.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8106e-1.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8411-2.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8411-1.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8402-1.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168f-2.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168f-1.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8105e-1.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168e-3.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168e-2.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168e-1.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168d-2.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168d-1.fw for module r8169
Generating grub configuration file ...
#sudo dpkg --install linux-headers-4.14.132-rtai-amd64_4.14.132-rtai-amd64-1_amd64.deb
OK
#sudo dpkg --install rtai-modules-4.14.132_5.2.2-linuxcnc_amd64.deb
OK
#sudo dpkg --install linuxcnc_2.8.0.pre1.4891.gadf1eff73_amd64.deb
dpkg: dependency problems prevent linuxcnc configuration:
linuxcnc depends on libboost-python1.62.0; however:
Package libboost-python1.62.0 is not installed.
linuxcnc depends on libgtk2.0-0 (> = 2.8.0); however:
Libgtk2.0-0 package is not installed.
linuxcnc depends on libmodbus5 (> = 3.0.2); however:
Libmodbus5 package is not installed.
linuxcnc depends on libreadline5 (> = 5.2); however:
Libreadline5 package is not installed.
linuxcnc depends on libtk8.6 (> = 8.6.0); however:
Libtk8.6 package is not installed.
linuxcnc depends on tcl8.6; however:
Package tcl8.6 is not installed.
linuxcnc depends on tk8.6; however:
Package tk8.6 is not installed.
linuxcnc depends on bwidget (> = 1.7); however:
Bwidget package is not installed.
linuxcnc depends on libtk-img (> = 1.13); however:
Libtk-img package is not installed.
linuxcnc depends on python2.7-tk; however:
Python2.7-tk package is not installed.
linuxcnc depends on python2.7-glade2 | python-glade2; however:
Python2.7-glade2 package is not installed.
Python-glade2 package is not installed.
linuxcnc depends on python2.7-numpy | python-numpy; however:
Python2.7-numpy package is not installed.
Python-numpy package is not installed.
linuxcnc depends on python2.7-imaging | python-imaging | python-pil; however:
Python2.7-imaging package is not installed.
Python-imaging package is not installed.
Python-pil package is not installed.
linuxcnc depends on python2.7-imaging-tk | python-imaging-tk; however:
Python2.7-imaging-tk package is not installed.
Python-imaging-tk package is not installed.
linuxcnc depends on python-gtksourceview2; however:
Python-gtksourceview2 package is not installed.
linuxcnc depends on python-vte; however:
Python-vte package is not installed.
linuxcnc depends on python-gst-1.0; however:
Python-gst-1.0 package is not installed.
linuxcnc depends on python-xlib; however:
Python-xlib package is not installed.
linuxcnc depends on python-gtkglext1; however:
Python-gtkglext1 package is not installed.
linuxcnc depends on python-configobj; however:
Python-configobj package is not installed.
linuxcnc depends on tclreadline; however:
Tclreadline package is not installed.
linuxcnc depends on tclx; however:
Tclx package is not installed.
linuxcnc depends on mesa-utils; however:
Mesa-utils package is not installed.
linuxcnc depends on blt; however:
Blt package is not installed.
dpkg: error processing the linuxcnc package (--install):
dependency problems - leaving unconfigured
Processing triggers for libc-bin (2.28-10) ...
Processing triggers for systemd (241-7 ~ deb10u4) ...
Processing triggers for gnome-menus (3.31.4-3) ...
Processing triggers for desktop-file-utils (0.23-4) ...
Processing triggers for mime-support (3.62) ...
Processing triggers for man-db (2.8.5-2) ...
Processing triggers for shared-mime-info (1.10-1) ...
Errors were encountered while processing:
linuxcnc
Testing Ubuntu 10 with Linuxcnc, the jitter is also low, at most 18000, when I try Debian, the problem I explained above happens.
Similar to what happens with the motherboard where I am with the geforce FX5200.
  • Moderator
  • Moderator
25 Aug 2020 20:07 #179443 by tommylight
If you have the time, try using Mint 19.3 with Mate desktop and the RTAI stuff, it worked for me, twice.
26 Aug 2020 01:54 - 26 Aug 2020 02:45 #179480 by aparecido
I found this tutorial that you posted step by step, I will test it.
forum.linuxcnc.org/9-installing-linuxcnc...nd-easy-installation
Thank you
Last edit: 26 Aug 2020 02:45 by aparecido.
Time to create page: 0.109 seconds
