Hopefully I can post this here. Design program
- Aldenflorio
- Thank you received: 15
18 Aug 2020 18:25 #178618
by Aldenflorio
Hopefully I can post this here. Design program was created by Aldenflorio
What are some designing programs that work well in accordance with linuxcnc? I’m building a plasma cnc so all I need is 2d and I don’t need it to be super advanced. I’d prefer for it to easy to understand though I’m not against learning. And I would like it to be free. Could
- Thank you received: 7468
18 Aug 2020 21:08 #178632
Replied by tommylight on topic Hopefully I can post this here. Design program
Inkscape.
The following user(s) said Thank You: Aldenflorio
- Aldenflorio
19 Aug 2020 02:17 #178665
by Aldenflorio
Replied by Aldenflorio on topic Hopefully I can post this here. Design program
Thank you
- AgentWD40
- Thank you received: 96
19 Aug 2020 02:21 #178666
by AgentWD40
Replied by AgentWD40 on topic Hopefully I can post this here. Design program
I like librecad for quick 2d parts... I need to learn fusion.
- anfänger
- Thank you received: 256
19 Aug 2020 04:51 #178671
by anfänger
Replied by anfänger on topic Hopefully I can post this here. Design program
Qcad has a free version
19 Aug 2020 06:31 #178680
Forgot to mention, Inkscape will export gcode ready for use in LinuxCNC.
With FreeCAD and QCAD you will need to use dxf2gcode that is also very easy to use.
- Aldenflorio
19 Aug 2020 06:50 #178685
by Aldenflorio
Thank you all, I’ll try each of them
- anfänger
19 Aug 2020 07:51 #178687
by anfänger
Quad should have a gco generator but I don’t know if they have it in the community version.
I rarely use it anymore since I have fusion.
- Thank you received: 1472
23 Aug 2020 17:28 #179120
FreeCAD is capable of generating quite nice G-code on it's own, including reasonably good HSM tool paths.
Replied by Todd Zuercher on topic Hopefully I can post this here. Design program
23 Aug 2020 17:49 #179123
Now that you mention it, i recall you mentioning it a while back also, but must have forgotten about it.
Thank you, Todd.
Oh, that is nice.FreeCAD is capable of generating quite nice G-code on it's own, including reasonably good HSM tool paths.
Thank you, Todd.
Time to create page: 0.144 seconds
