Hopefully I can post this here. Design program
- Aldenflorio
- Thank you received: 15
18 Sep 2020 15:12 - 18 Sep 2020 15:12 #182657
by Aldenflorio
Replied by Aldenflorio on topic Hopefully I can post this here. Design program
I’d be using inches. But that I you. I’ll copy the extension in a bit and let you know how it goes. Thank you
Last edit: 18 Sep 2020 15:12 by Aldenflorio.
- Aldenflorio
18 Sep 2020 16:56 - 18 Sep 2020 18:17 #182663
by Aldenflorio
Ok I did that. now I have this problem. I hit begin execute, it goes to the x and y, then z goes down until it trips the floating switch, then it backs up and goes down again tripping the switch for a second time. After this it just goes strait up and stops doing anything. Linux says floating switch activated program paused
Last edit: 18 Sep 2020 18:17 by Aldenflorio.
- Aldenflorio
18 Sep 2020 19:58 - 18 Sep 2020 19:58 #182676
by Aldenflorio
Ok so scratch everything. I’m beyond annoyed with this especially since it’s the last step to getting my machine finished so I’m trying to figure out what I can. With that I deleted Inkscape completely. I have now installed Inkscape again, i now have version 1.01 here’s my issue now
Extensions> Gcodetools> tools library> click plasma then apply
I receive this error message:
Fatal Python error :Py_Initialize: unable to get the locale encoding
imporError: No module named ‘encodings’
Current thread 0x00007fa821f93700 (most recent call first)
Last edit: 18 Sep 2020 19:58 by Aldenflorio.
- Thank you received: 4144
18 Sep 2020 23:11 #182688
Replied by rodw on topic Hopefully I can post this here. Design program
I think there might be a confusion between Python 2.7 and Python 3. This has some info.
stackoverflow.com/questions/38132755/imp...dule-named-encodings
- Aldenflorio
19 Sep 2020 01:34 - 19 Sep 2020 01:34 #182696
by Aldenflorio
This link seems to be talking about Ubuntu. I'm using Debian live. and i tried what it said there anyways but it didnt help. ive posted on multiple places and am still searching. no one seems to know
Last edit: 19 Sep 2020 01:34 by Aldenflorio.
- Aldenflorio
20 Sep 2020 04:27 - 20 Sep 2020 04:56 #182815
by Aldenflorio
Ive started trying other programs bc im having an annoying amount of problems with inkscape. Im trying librecad now and like it so far. its easy and closer to what im use to. i have one question at the moment, how do i save files as gcode? what else do i need?
I have the same questions for FreeCAD
Last edit: 20 Sep 2020 04:56 by Aldenflorio.
- Himarc3D
- Thank you received: 49
20 Sep 2020 05:58 #182820
by Himarc3D
Replied by Himarc3D on topic Hopefully I can post this here. Design program
I never used both just Autocad but if librecad or freecad save in dxf format you can convert dxf to gcode, i read about it at cnczone, never converted anything yet. The gcode i know is from 3d printer and dont follow the standard i think.
- Himarc3D
20 Sep 2020 06:08 #182821
by Himarc3D
Googled dxf converter
wiki.linuxcnc.org/cgi-bin/wiki.pl?Simple...NC_G-Code_Generators
- Aldenflorio
20 Sep 2020 07:04 #182827
by Aldenflorio
Thanks. I’ll check tomorrow morning
- Aldenflorio
20 Sep 2020 16:53 - 20 Sep 2020 17:40 #182925
by Aldenflorio
I'm having trouble with the installation of dxf2gcode. when i download it it just shows up as a folder
Figured it out and no longer having that problem
Last edit: 20 Sep 2020 17:40 by Aldenflorio. Reason: Figured it out
Time to create page: 0.168 seconds
