Hopefully I can post this here. Design program
  • Aldenflorio
  • Aldenflorio's Avatar Topic Author
  • Platinum Member
  • Platinum Member
18 Aug 2020 18:25 #178618 by Aldenflorio
What are some designing programs that work well in accordance with linuxcnc? I’m building a plasma cnc so all I need is 2d and I don’t need it to be super advanced. I’d prefer for it to easy to understand though I’m not against learning. And I would like it to be free. Could
  • Moderator
  • Moderator
18 Aug 2020 21:08 #178632 by tommylight
Replied by tommylight on topic Hopefully I can post this here. Design program
Inkscape.
The following user(s) said Thank You: Aldenflorio
  • Aldenflorio
  • Platinum Member
  • Platinum Member
19 Aug 2020 02:17 #178665 by Aldenflorio
Replied by Aldenflorio on topic Hopefully I can post this here. Design program
Thank you
19 Aug 2020 02:21 #178666 by AgentWD40
Replied by AgentWD40 on topic Hopefully I can post this here. Design program
I like librecad for quick 2d parts... I need to learn fusion.
19 Aug 2020 04:51 #178671 by anfänger
Replied by anfänger on topic Hopefully I can post this here. Design program
Qcad has a free version
  • Moderator
  • Moderator
19 Aug 2020 06:31 #178680 by tommylight
Forgot to mention, Inkscape will export gcode ready for use in LinuxCNC.
With FreeCAD and QCAD you will need to use dxf2gcode that is also very easy to use.
  • Aldenflorio
  • Platinum Member
  • Platinum Member
19 Aug 2020 06:50 #178685 by Aldenflorio
Thank you all, I’ll try each of them
19 Aug 2020 07:51 #178687 by anfänger
Quad should have a gco generator but I don’t know if they have it in the community version.
I rarely use it anymore since I have fusion.
23 Aug 2020 17:28 #179120 by Todd Zuercher
Replied by Todd Zuercher on topic Hopefully I can post this here. Design program
FreeCAD is capable of generating quite nice G-code on it's own, including reasonably good HSM tool paths.
  • Moderator
  • Moderator
23 Aug 2020 17:49 #179123 by tommylight
Oh, that is nice.
Now that you mention it, i recall you mentioning it a while back also, but must have forgotten about it.
Thank you, Todd.
Time to create page: 0.129 seconds
