How to read "Machine configuration directory" in HAL userspace component
3 years 10 months ago #259401 by andypugh
how can you shut down Linuxcnc in a controlled way with an external command;
External command from where?
pkill -3 axis
will work, but seems to always pop-up the error report dialog box in my testing.
3 years 10 months ago - 3 years 10 months ago #259429 by udoS
[justify]
@andypugh
Hi andypugh,
"pkill -3 axis" works OK and I don't get that popup window;
But only if you use axis; running in the backyard so to speek;
It looks like everything is cleaned out;
I can send it with QProcess;
I thought there would be an internal Lcnc function
or a NML command to shut it down in a controlled way;
or else I will stick to the kill;
I'm starting LinuxCNC out of my Qt c++ app because I need access to the HAL / PINS;
Best Regards
p.s. is there a privat channal to talk; I have a realy  basic question regarding LinuxCNC;
or else a mail uschlicher at t-online dot de
[/justify]
Last edit: 3 years 10 months ago by udoS.
3 years 8 months ago #264685 by udoS
Hi to ALL;
How do I get the info from Lcnc (nml ? ) what the gantry joints are in relation to the axis;
Like in axis at startup you see the 4 joints but after REF you have your 3 axis. No in manual mode you can only move e.g. joint1 and joint3 together;
thanks
3 years 8 months ago #264692 by udoS
Oh, and about the
You can get from: emcStatusTaskIniFilename from nml;
like this:
char    emcStatusTaskIniFilename[255];
EMC_STAT *emcStatus = static_cast<EMC_STAT*>(_nmlStat->get_address());
emcStatusTaskIniFilename[0] = 0;
                    strncpy(emcStatusTaskIniFilename, emcStatus->task.ini_filename, sizeof(emcStatusTaskIniFilename));
emcStatusTaskIniFilename and there you have it;
Time to create page: 0.188 seconds
