Wrong preview
- zz912
- Thank you received: 98
02 Jan 2021 20:09 #193884
by zz912
Wrong preview was created by zz912
Hello,I have problem with wrong preview on my lathe.I made my config by Pncconf
Then I noticed, that in simulator is preview good.
I gradually tried to mix files from the simulation and from Pncconf and other simulator and ... I dont konw. I found that the sim.var file does this.I can run a simulation with a good sim.var file where the preview is correct.I can run a simulation with a bad sim.var file where the preview is incorrect.Unfortunately, I don't know what the sim.var file is for and how to use this finding to fix preview for real machine.
- zz912
02 Jan 2021 20:46 - 02 Jan 2021 20:53 #193888
by zz912
Replied by zz912 on topic Wrong preview
I looked for a mistake and found it. It does G54. If G54 is an integer, then the preview is fine. If G54 is a real number, then the preview is bad. This problem is not in Axis. I've been looking for this mistake all day.
Last edit: 02 Jan 2021 20:53 by zz912.
- newbynobi
- Thank you received: 394
04 Jan 2021 14:50 #194041
by newbynobi
Replied by newbynobi on topic Wrong preview
Hallo,
this is a known problem og the glade preview widget called gremlin.
I decided not to include any affort in this tool, because the change to GTK3 and python 3 will lead to a complete new preview, hopefully also with 3D features.
Norbert
Norbert
- zz912
04 Jan 2021 14:58 #194044
by zz912
Thank you for responce.
- HansU
- Thank you received: 217
23 Jan 2021 10:38 #196322
by HansU
Replied by HansU on topic Wrong preview
But the preview in axis don't use gremlin, is that right?
Even though some solid preview would be nice...
Hopefully not to much 3D feature so that it don't stress the cpu too much.Hallo,
Norbert
- Thank you received: 7488
23 Jan 2021 11:48 #196328
forum.linuxcnc.org/21-axis/34860-gremlin-view
Replied by tommylight on topic Wrong preview
Pretty sure it does:But the preview in axis don't use gremlin, is that right?
- HansU
23 Jan 2021 18:20 #196351
by HansU
But then I wonder why the displayed maximum values of the part are shown wrong with gremlin in gmoccapy and shown right in axis...
- Thank you received: 2181
23 Jan 2021 19:40 #196354
Replied by cmorley on topic Wrong preview
gremlin, axis and qtvcp use much of the same underlying library code, but they are different programs.
There seems to be few openGL programmers in linuxcnc so we all just use the code that works and build on that.
- HansU
14 Feb 2021 18:21 #198823
by HansU
But then I wonder why the display differs from gmoccapy to axis.
Have a look at the value for maximum Z.
But on another computer it is displayed correctly even in gmoccapy. Maybe something regarding the graphics card driver?
It gmoccapy:
in axis:
It gmoccapy:
in axis:
- zz912
05 Mar 2021 18:44 #201116
by zz912
Has anybody solution for this problems? I dont want use AXIS.
Time to create page: 0.800 seconds
