spindle control
- jefsaro
- Thank you received: 4
07 Jan 2021 06:48 #194324
by jefsaro
spindle control was created by jefsaro
hello friends, now the fanuc starts to run, i have a problem with the spindle speed, with m3 no problem, but with m4 it runs directly at 6000 tr, with any speed i put, i run with a hitachi wj200 vfd and spindle senses with gpio.
any ideas ?
any ideas ?
- Thank you received: 7471
09 Jan 2021 16:20 #194605
Replied by tommylight on topic spindle control
Did you manage to fix this ?
- chris@cnc
- Thank you received: 140
09 Jan 2021 19:12 #194637
by chris@cnc
Replied by chris@cnc on topic spindle control
your spindel section in hal looks strange. How does you power on the spindle?
first:
second:check where your spindle is connect and correct this lines.
first:
net spindle-output => hm2_5i25.0.7i76.0.0.spinout
net spindle-enable => hm2_5i25.0.7i76.0.0.spinena
#net spindle-ccw => hm2_5i25.0.7i76.0.0.spindir second:
# --- SPINDLE-CW ---
net spindle-cw hm2_5i25.0.7i76.0.0.output-00
# --- SPINDLE-CCW ---
net spindle-ccw hm2_5i25.0.7i76.0.0.output-01Please Log in or Create an account to join the conversation.
- jefsaro
10 Jan 2021 06:49 #194687
by jefsaro
Replied by jefsaro on topic spindle control
if i comment
net broche-sortie => hm2_5i25.0.7i76.0.0.spinout
the spindle don't turn
- chris@cnc
10 Jan 2021 11:12 #194707
by chris@cnc
How do you power on the spindle. Did you connect analog spindle control?
if yes delete this lines
and try this way
net spindle-ccw hm2_5i25.0.7i76.0.0.output-01and try this way
net spindle-ccw => hm2_5i25.0.7i76.0.0.spindirPlease Log in or Create an account to join the conversation.
- jefsaro
10 Jan 2021 16:07 - 10 Jan 2021 16:21 #194737
by jefsaro
i forgot this message from andy forum.linuxcnc.org/38-general-linuxcnc-q...itaachi-w200?start=0
Last edit: 10 Jan 2021 16:21 by jefsaro.
- Thank you received: 4654
11 Jan 2021 00:43 #194830
Replied by andypugh on topic spindle control
I think that the problem is PID windup in reverse, as you have closed-loop spindle control.
You need to be careful when the encoder and linuxcnc understand negative speed requests, but the spindle drive does not.
You might need to pass the pid.s.out through an abs component before passing it to the spinout pin.
Then use the abs.0.is-negative and is-positive pins to control the spindle direction.
Sorry to be so vague, but I am fuzzy on quite how the 7i76 spindle interface works (ie spindir and the physical pins)
- Thank you received: 2181
11 Jan 2021 01:14 - 11 Jan 2021 01:15 #194838
Replied by cmorley on topic spindle control
Ya I bet you set in pncconf +-10 volt and the 7i76 doesn't support +-10 volt.
If you redo pncconf without the +-10 set It will change the signal to use the absolute version and properly set the output scales in the INI
Last edit: 11 Jan 2021 01:15 by cmorley.
- alkabal
- Thank you received: 52
11 Jan 2021 01:22 #194840
by alkabal
Replied by alkabal on topic spindle control
Hi
I have try to write that for this user, can you check quicly ?
forum.linuxcnc.org/38-general-linuxcnc-q...ient?start=20#194807
- jefsaro
11 Jan 2021 05:30 #194848
by jefsaro
non j'ai regler en 0 +10v car le vfd hitachi ne prend pas en charge - 10
Time to create page: 1.023 seconds
