adding auto leveling to linuxCnc
- Ewok2
5 years 7 months ago #203139
by Ewok2
adding auto leveling to linuxCnc was created by Ewok2
Hi
Don't know how to search
I am using linuxCnC to make PCB.
I need to had the auto leveling function to probe the "height" of many point of the copper pcb befor engraving.
Is it possible with linuxcnc ?
5 years 7 months ago #203170
Replied by andypugh on topic adding auto leveling to linuxCnc
It is possible, but I don't know of any turnkey implementations.
The way to do it now would be using "External Offsets" but I am not sure what one would use to generate the offsets.
How many points are you probing?
I think that this idea had merit, and parts of it might be re-usable:
wiki.linuxcnc.org/cgi-bin/wiki.pl?ProbeKins
The problem with that implementation was discontinuities in the kinematics. This would not be a problem if the offset was applied as an "external offset" separately from kinematics.
linuxcnc.org/docs/2.8/html/motion/external-offsets.html
5 years 7 months ago #203171
NOTE: I haven't been able to find the stlcorr.py or any of the other files mentioned.
- robertspark
- Thank you received: 216
5 years 7 months ago - 5 years 7 months ago #203176
by robertspark
Replied by robertspark on topic adding auto leveling to linuxCnc
bitbucket.org/daedelus1982/autolevellerae/src/master/
www.autoleveller.co.uk/
autoleveler (not used, but apparently compatible with LCNC)
tell us how you get on
Last edit: 5 years 7 months ago by robertspark.
- Willheg
5 years 7 months ago #203177
by Willheg
Replied by Willheg on topic adding auto leveling to linuxCnc
Hi there,
I looked into this many moons ago when I built my machine and am currently not near my computers due to being at work.
I did a quick search and found this link, kingofprotons.blogspot.com/p/pcb-autolevelling.html?m=1
I think from memory this is what I was looking at using but never got round to trying it as of yet, but it has a ok write up to follow and links so software to probe the board first, then adjust your selected file with the data, then cut your board.
I hope this is something on the path of what you where after.
I thought I had another way but dont seem to be able to find it at the moment.
- Hakan
- Thank you received: 454
5 years 7 months ago #203178
by Hakan
Replied by Hakan on topic adding auto leveling to linuxCnc
It is available here too
I used it some years ago. There were some things around the java version to use.
And to use a locale that uses . as decimal separator and not ,
Other than that it worked just fine.
Time to create page: 0.311 seconds
