adding auto leveling to linuxCnc
5 years 7 months ago #203182 by tommylight
The following user(s) said Thank You: kostas, robertspark
5 years 7 months ago #203195 by scotth
Replied by scotth on topic adding auto leveling to linuxCnc
Will this work for 3d compensation to offset pitch and roll in X, Y and Z axis movement?
5 years 7 months ago #203206 by jbraun
Replied by jbraun on topic adding auto leveling to linuxCnc
G-Code Ripper. I've used it for years,
scorchworks.com/Gcoderipper/gcoderipper.html
5 years 7 months ago #203284 by Ewok2
Replied by Ewok2 on topic adding auto leveling to linuxCnc
Hello
Thanks for all the reply. I have to look all the proposal :-)
I had already seen Autoleveller but it seem's old. compatible with Java8 and we are 11...
I try to run but had error message.
I don't know how many test point I need... my PCB is 10cm x 16cm. So I think between 1 for 1 square cm would be the maximum...
I will try and let you know the result!
5 years 7 months ago #203301 by robertspark
Replied by robertspark on topic adding auto leveling to linuxCnc
tommylight wrote:
github.com/scottalford75/LinuxCNC-3D-Pri.../master/compensation
thats a nice neat component {just started reading about external offsets}
5 years 7 months ago #203311 by tommylight
Replied by tommylight on topic adding auto leveling to linuxCnc
Bumped in it some 10 days back and left the tabs open thinking of putting it somewhere in the forum, then i see the question here. Lucky ! :)
Still i think it is about time we have a 3D printer section on this forum, mainly because i have one and already have all the parts for building another one using servo motors just to see how far i can push it, thinking i need a granite base for it .... :)
Time to create page: 0.938 seconds
