I made little progress. Added some technical details. It can look a bit messy, but for now it's ok.
The controls are fully functional. Now focussing on how to teach and how to store and edit this data in opencascade.
1.Moving the robot in tool direction is done! This works very nice. Also mdi commands are working.
2.When for example teaching a line, it will attach the toolposition's (euler angles) at the begin- and the end of the line to teach.
When clicking on the teached line, you can simple delete it (and it's childs) by one command. This is quite nice.
- The green cone is startpoint.
- The red cone is a halcommand including position & euler angles.
- The black cone is the endpoint.
3. Todo is getting the possibility to edit existing line point's to enable live preview. How the editing works, i have to ask at the opencascade help center. So far i haven't seen a solution how to do this.
So far so good.
