G71
03 Oct 2021 10:08 #222088 by andypugh
Replied by andypugh on topic G71
How do I obtain the 'name-of-patch-file' file?
Do I cut and past the script into Geany and save it under any file name with .patch extension, or is there actually a file to download or link to ?
You should be able to "save as" direct from the web browser.
03 Oct 2021 10:16 #222089 by andypugh
It's probably worth reading this: www.thegeekstuff.com/2014/12/patch-command-examples/
(especially the dry-run option)
The two things that can go wrong are
1) Not being in the same place in the source tree as the patch was created, as the paths are relative. the p<number> option controls this.
2) Not having exactly the same source files as the patch was created against. The patch command can deal with this to an extent, and this can be tweaked with the -F option.
man7.org/linux/man-pages/man1/patch.1.html
19 Jun 2022 14:29 #245432 by DoWerna
Replied by DoWerna on topic G71
i ask myself the same question. my lathe is getting ready now.
runs with LCNC 2.8.2 Gmoccapy and the lathe macros from andy.
g71 and g72 would really be a great added value.
I only have the home user version fusion360, I often make cylinder heads for two-stroke engines. (the combustion chamber)
Would rather write the gcode myself instead of setting up fusion.
How stable is buidbot 2.9?
Don't want to break my working setup.
will the macros work under 2.9
or, is it predicteble when 2.9 will be released normally?
21 Jun 2022 23:09 #245565 by andypugh
Fairly stable.
From my testing last night, no they don't. This is a GTK3 issue that I have not managed to get to for over a year.
The following user(s) said Thank You: DoWerna
22 Jun 2022 11:26 #245586 by DoWerna
thanks andy .
so I stay with 2.8.2, I do not want to lose the macros in any case.
They are too useful.
I'll try to set up fusion 360.
23 Jun 2022 11:11 #245667 by rider-83
Replied by rider-83 on topic G71
I upgraded to 2.9 for the use of the G71 cycles and had a real hard time. It really wasn't worth the trouble, so I had to revert back to 2.8.2
23 Jun 2022 11:31 #245668 by andypugh
What problems did you have? Was it general Linux problems or specific G71 problems?
27 Jun 2022 05:25 #245982 by rider-83
It's quite a while back now, so I don't remember exactly, but there where many issue with missing packages and a lot of manual work in order to get it to install correctly. After that the main issue was that the GUI woudn't re-size to match my monitor size and the menus were off the screen. I started a thread on this issu but got no where with it, so I abandoned it.
29 Jun 2022 20:23 #246200 by andypugh
Which GUI? And which screen size? Axis doesn't fit on 800x600 (I just tried) but seems OK on 1024x768.
30 Jun 2022 05:19 #246250 by rider-83
It was GMOCCAPY. I started a thread on this issue, but got nowhere so I abandoned it a long time ago .
Time to create page: 0.137 seconds
