G71
- Thank you received: 4648
03 Jul 2022 09:41 #246488
Replied by andypugh on topic G71
I am currently seeing the same thing in gmoccapy if (and only if) the lathe macros are loaded.
The screen needs to be excessively large to see the tabs. (more than 1800 pixels wide)
But this is not a problem without the lathe macros (Or, possibly, it's the same with any custom tabs, I have not yet done that experiment)
I am trying to get the macros working with GTK3, so perhaps I will end up fixing this by accident.
13 Jul 2022 09:40 #247219
forum.linuxcnc.org/41-guis/26550-lathe-macros?start=240#247195
I think that this issue might be fixed. The user tab and menus are now visible even is Gmoccapy is in a small window.
Resizing could still be rather better, but it does work (the content is created 4 pixels smaller than the window, then resized when the window resizes, making another 4 pixels available to shrink in to, and so on.
- MRx
- Thank you received: 9
16 Jul 2022 10:31 #247442
by MRx
Replied by MRx on topic G71
There are still a few issues with G71 and LinuxCNC 2.9
github.com/LinuxCNC/linuxcnc/issues/1146...uecomment-1185727887
I played around and added dwelling and diving in feed rate support yesterday.
in case something's wrong with the path linuxcnc might be stuck and the memory might grow (I haven't experienced that for quite some time because I have my way of using it)
Time to create page: 0.078 seconds
