mesa 7i96 connection refused
- Aaron3309
19 Apr 2021 13:07 #206381
by Aaron3309
mesa 7i96 connection refused was created by Aaron3309
So i am running a mesa 7i96 card for my plasma machine, the mini pc i was using took a crap on me so i am trying to set up a new tower but i am getting a connection refused error when opening my configuration. I found some older posts that said to check the results of ip a and it shows my ethernet connection is enp3s0 but the ip address matched the card at 192.168.121.1. so i changed the jumpers to 10.10.10.10 and set up a new test configuration with that ip. now when I run ip a under enps03 it shows 10.10.10.10 and i get the same connection refused error. I have gone through every single tutorial on the internet on how to change to a static ip and i cannot get it to take. If i pull up my network directory to edit it enp3s0 is not even there only one entry for loopback. i tried adding the enp3s0 in the format of the hm2-eth manual and nothing happens. i am running a fresh installation of debian buster downloaded from the link in the plasma c userguide. any ideas would be greatly appreciated ive been staring at this screen for 12 plus hours and have gotten nowhere.
- Aaron3309
19 Apr 2021 13:56 #206382
by Aaron3309
Replied by Aaron3309 on topic mesa 7i96 connection refused
Also i am able to ping the card successfully if that information helps.
- Thank you received: 7478
19 Apr 2021 14:08 #206389
Replied by tommylight on topic mesa 7i96 connection refused
Same IP on Mesa and PC will not work, set the PC to anything but 10 at the end, like 10.10.10.11.
And you are not pinging the card, the PC is replying.
- Aaron3309
19 Apr 2021 14:19 #206391
by Aaron3309
changing the pc is what i am having the issue with, it wont seem to take the change. where do you suggest i change it at? when i run /etc/network/interfaces the ethernet does not show in the list, i tried to add it but it changes nothing.
- Aaron3309
19 Apr 2021 14:31 - 19 Apr 2021 14:41 #206392
by Aaron3309
Here are some screen shots of when i run ip a, /etc/network/interfaces and of the error when opening my machine. At first i posted the wrong image of the error code but i edited.
Last edit: 19 Apr 2021 14:41 by Aaron3309.
- Thank you received: 5326
19 Apr 2021 15:28 - 19 Apr 2021 15:28 #206402
Replied by PCW on topic mesa 7i96 connection refused
You cannot source the interfaces file, its not a script.
Its executed when you bring an interface up or down.
Last edit: 19 Apr 2021 15:28 by PCW.
- Aaron3309
19 Apr 2021 15:37 #206404
by Aaron3309
Pardon my ignorance but i dont know what that means, what do i need to do to fix my issue?
19 Apr 2021 15:52 - 19 Apr 2021 16:12 #206406
Adding this to your interfaces file should fix it:
auto enp3s0
iface enp3s0 inet static
address 10.10.10.100/24
Then set the interface up with
sudo ifup -a
Then verify that it worked by running
ip a
auto enp3s0
sudo ifup -a
ip a
Last edit: 19 Apr 2021 16:12 by PCW.
- Aaron3309
19 Apr 2021 16:28 #206411
by Aaron3309
Did i put it in the right place? (attachment) i did the sudo ifup -a and nothing took, did sudo if up enp3s0 and it said network already up, tried down them back up and still nothing took.
If i type ip a with the mesa card powerd up i get
2: enp3s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether f0:4d:a2:fe:86:3e brd ff:ff:ff:ff:ff:ff
inet 10.10.10.10/8 brd 10.255.255.255 scope global enp3s0
valid_lft forever preferred_lft forever
inet6 fe80::f24d:a2ff:fefe:863e/64 scope link
If i do it with the mesa card off i get
19 Apr 2021 16:49 - 19 Apr 2021 16:51 #206417
Could you please copy/paste you interfaces file here
If the interfaces file does not take, it usually because there is a error/typo in the file
Last edit: 19 Apr 2021 16:51 by PCW.
Time to create page: 1.885 seconds
