mesa 7i96 connection refused
- Thank you received: 5321
19 Apr 2021 19:45 #206461
Replied by PCW on topic mesa 7i96 connection refused
No need to re-install just, delete the WICD wired connection
19 Apr 2021 19:49 #206463
What wicd says is not relevent
what do the commands
ip a
followed by
ping 10.10.10.10
report?
ip a
followed by
ping 10.10.10.10
report?
- Aaron3309
19 Apr 2021 19:53 #206464
by Aaron3309
Replied by Aaron3309 on topic mesa 7i96 connection refused
ip a returned
2: enp3s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether f0:4d:a2:fe:86:3e brd ff:ff:ff:ff:ff:ff
inet 10.10.10.100/24 brd 10.10.10.255 scope global enp3s0
valid_lft forever preferred_lft forever
inet6 fe80::f24d:a2ff:fefe:863e/64 scope link
ping returned :
destination host unreachable
ping returned :
19 Apr 2021 19:57 #206465
OK are you sure the 7I96 is set for 10.10.10.10 (W5 down W6 up)
and that you have power cycled the 7I96 after changing the jumpers?
- Aaron3309
19 Apr 2021 20:25 #206472
by Aaron3309
Yes i have w5 down w6 up, i have had it off and on many times.
after trying to ping 10.10.10.10 i tried ip a again and now it shows
19 Apr 2021 20:45 - 19 Apr 2021 20:46 #206476
That's odd even if the Ethernet is unconnected, my host static
IP address stays
Maybe that's related to the fact that you have IPV6 enabled
you might try turning IPV6 off
There are a number of ways to do this, perhaps the simplest is via grub by adding
ipv6.disable=1 to the kernel command line
Is it possible someone changed the default EEPROM IP address on the 7I96?
(the 10.10.10.10 is changeable via mesaflash)
One way to check this is to set the 7I96 back to 192.168.1.121, change the
host address to 192.168.1.100 and ping the card to see if it works.
If so you can read/set the cards EEPROM IP address with mesaflash
IP address stays
Last edit: 19 Apr 2021 20:46 by PCW.
- Aaron3309
19 Apr 2021 21:06 #206477
by Aaron3309
i have tried it with both the 192.168.1.121 and the 10.10.10.10. I am the only person who has ever used this so i dont know how it could have been changed. it worked fine on my previous computer. i turned off ivp 6 i think but the freaking ip address still changes, after running ifup -a ifdown-a it sows the correct number but if i do anything at all even just ping any ip or try to open my machine it reverts to this
19 Apr 2021 21:10 #206478
What happens if you setup a static IP address of 10.10.10.100 in wicd?
I still get the impression the wicd is messing with things
Replacing wicd with netmanager might also help (since netmanager
respects interfaces file settings)
- Aaron3309
19 Apr 2021 21:20 #206479
by Aaron3309
When i do that it shows in the ip a command as 10.10.10.100/8 but when i try to open my machine it says network unreachable
19 Apr 2021 21:42 #206480
If you get "network unreachable" and" ip a" shows that the static
address is right and the link is "UP" this means is still a network configuration error on the host. Not sure what.
At this point I would probably remove wicd and install netmanager
Time to create page: 0.145 seconds
