parallel port drivers
- Dragonbitscnc
05 Jun 2021 22:55 #211258
by Dragonbitscnc
parallel port drivers was created by Dragonbitscnc
Hi, I'm trying to get my parallel port working, I'm trying to unzip my drivers.
And I get stuck here!
john@LinuxCNC:~/Downloads/parportdrive$ pwd
/home/john/Downloads/parportdrive
john@LinuxCNC:~/Downloads/parportdrive$ ls
'[oxfordpcie] linux serial and parallel cards.zip'
john@LinuxCNC:~/Downloads/parportdrive$ unzip '[oxfordpcie] linux serial and parallel cards.zip'
bash: unzip: command not found
Can you see something I can't ? Or if I'm doing this wrong
- Thank you received: 5325
05 Jun 2021 23:57 - 06 Jun 2021 00:00 #211259
Replied by PCW on topic parallel port drivers
1. I don't think you need a driver for the Oxford Semi parts
(its certainly not used by LinuxCNC)
2. To use a command line utility on a file name with embedded spaces
try:
unzip [ and the a tab and return
( The '[' is the first character of the file name and the tab expands that into the
file name with the needed escape characters for the spaces )
try:
Last edit: 06 Jun 2021 00:00 by PCW.
- BeagleBrainz
- Visitor
06 Jun 2021 01:03 #211265
by BeagleBrainz
Replied by BeagleBrainz on topic parallel port drivers
the unzip\zip package isn't installed
For debian
The below is the output when it can't find the file.
For debian
sudo apt-get update
sudo apt-get install unzipThe below is the output when it can't find the file.
rmurphy@thinkPad-t530:~$ unzip '[oxfordpcie] linux serial and parallel cards.zip'
unzip: cannot find or open [oxfordpcie] linux serial and parallel cards.zip, [oxfordpcie] linux serial and parallel cards.zip.zip or [oxfordpcie] linux serial and parallel cards.zip.ZIP.
No zipfiles found.
06 Jun 2021 01:13 #211267
Oops, I didn't read the error carefully
But I still don't think the driver is needed for LinuxCNC
- Dragonbitscnc
06 Jun 2021 01:19 #211268
by Dragonbitscnc
Replied by Dragonbitscnc on topic parallel port drivers
john@LinuxCNC:~/Downloads/parportdrive$ unzip \[oxfordpcie\]\ linux\ serial\ and\ parallel\ cards.zip
Did'nt work . In the synaptic package manager there's zip-unzip to install, do I need one
to unzip, or dose Bash do that automatically?
- Thank you received: 7478
06 Jun 2021 01:29 #211270
Replied by tommylight on topic parallel port drivers
In a terminal
cat /proc/ioports | grep parport
post the result
post the result
- Dragonbitscnc
06 Jun 2021 02:05 #211271
by Dragonbitscnc
john@LinuxCNC:~/Downloads/parportdrive$ cat /proc/ioports | grep parport
0000-0000 : parport0
- BeagleBrainz
- Visitor
06 Jun 2021 02:05 #211272
by BeagleBrainz
linuxize.com/post/how-to-unzip-files-in-linux/
- Dragonbitscnc
06 Jun 2021 02:09 #211273
by Dragonbitscnc
I got this when I ran that comand with sudo
john@LinuxCNC:~/Downloads/parportdrive$ sudo cat /proc/ioports | grep parport
d010-d012 : parport0
d013-d017 : parport0
06 Jun 2021 09:22 #211283
In StepConfig enter this for the port address:
0xd010
0xd010
Time to create page: 0.293 seconds
