parallel port drivers
- Dragonbitscnc
06 Jun 2021 19:37 #211331
by Dragonbitscnc
Replied by Dragonbitscnc on topic parallel port drivers
kernel driver?
I unziped drivers for the parallel port
But I don' know what to do with them
- Thank you received: 5317
06 Jun 2021 19:38 #211332
Replied by PCW on topic parallel port drivers
Can you measure the direction lines to see if they change when jogging in either direction?
- Dragonbitscnc
06 Jun 2021 19:44 #211333
by Dragonbitscnc
I think I did that . And i made the change to 5000
Generated by stepconf 1.1 at Sun Jun 6 09:06:05 2021
# overwritten when you run stepconf again
loadrt [KINS]KINEMATICS
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS
loadrt hal_parport cfg="0xd010 out"
setp parport.0.reset-time 5000
loadrt stepgen step_type=0,0,0
loadrt pwmgen output_type=1
06 Jun 2021 19:47 - 06 Jun 2021 19:48 #211334
You dont need them. Linux already has a driver.
Do the direction lines change state when jogging in different directions?
kernel driver?
Last edit: 06 Jun 2021 19:48 by PCW.
- Dragonbitscnc
06 Jun 2021 19:48 #211335
by Dragonbitscnc
It's not moving!
I've hit a brick between the software and the hardware
06 Jun 2021 19:49 #211337
Again, do the direction lines change when you jog in different directions?
- Dragonbitscnc
06 Jun 2021 19:50 #211338
by Dragonbitscnc
on the software yes
06 Jun 2021 20:44 #211348
But do they change in the hardware? (voltmeter or even a LED would work to check)
Another option is to try the other address (0xd013)
- Dragonbitscnc
06 Jun 2021 20:53 #211349
by Dragonbitscnc
I changed that in HAL, ran my config, Got warning "Linux parallel port @ 53267 not found"
- Dragonbitscnc
06 Jun 2021 21:17 #211354
by Dragonbitscnc
I appreciate all the help, thank you.
I'm going t start a new thread with more detail.
Time to create page: 0.131 seconds
