parallel port drivers
06 Jun 2021 13:51 #211299 by Dragonbitscnc
Replied by Dragonbitscnc on topic parallel port drivers
ok I'll try that when I get to the shop. I'll let you know
06 Jun 2021 16:15 #211305 by Dragonbitscnc
no change, this is HAL file displaying change as out.
# Generated by stepconf 1.1 at Sun Jun 6 09:06:05 2021
# overwritten when you run stepconf again
loadrt [KINS]KINEMATICS
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS
loadrt hal_parport cfg="0xd010 out"
setp parport.0.reset-time 1000
loadrt stepgen step_type=0,0,0
loadrt pwmgen output_type=1
are drivers fir parallel port needed?
06 Jun 2021 16:27 #211306 by Dragonbitscnc
I found this video about parport @ the 2min mark he also had input
  • BeagleBrainz
  • BeagleBrainz's Avatar
  • Visitor
  • Visitor
06 Jun 2021 18:02 #211312 by BeagleBrainz
Replied by BeagleBrainz on topic parallel port drivers
Have a look at this thread, forum.linuxcnc.org/27-driver-boards/4254...ter-what-i-try-to-do there is some info about testing the parallel port, run that and see how you go.
06 Jun 2021 19:04 #211321 by Dragonbitscnc
this is coming up all 00's
john@LinuxCNC:~$ cat /proc/ioports* -v
0000-0000 : PCI Bus 0000:00
0000-0000 : dma1
0000-0000 : pic1
0000-0000 : timer0
0000-0000 : timer1
0000-0000 : keyboard
0000-0000 : PNP0C09:00
0000-0000 : EC data
0000-0000 : EC cmd
0000-0000 : rtc0
0000-0000 : dma page reg
0000-0000 : pic2
0000-0000 : dma2
0000-0000 : fpu
0000-0000 : iTCO_wdt
0000-0000 : pnp 00:00
0000-0000 : PCI conf1
0000-0000 : ACPI PM1a_EVT_BLK
0000-0000 : ACPI PM1a_CNT_BLK
0000-0000 : ACPI PM_TMR
0000-0000 : ACPI PM2_CNT_BLK
0000-0000 : pnp 00:02
0000-0000 : ACPI GPE0_BLK
0000-0000 : PCI Bus 0000:04
0000-0000 : 0000:04:00.0
0000-0000 : parport0
0000-0000 : PCI Bus 0000:02
0000-0000 : 0000:02:00.0
0000-0000 : 0000:00:02.0
0000-0000 : 0000:00:1f.4
0000-0000 : i801_smbus
0000-0000 : pnp 00:06
06 Jun 2021 19:08 #211322 by Dragonbitscnc
I used sudo and got this
john@LinuxCNC:~$ sudo cat /proc/ioports
[sudo] password for john:
0000-0cf7 : PCI Bus 0000:00
0000-001f : dma1
0020-0021 : pic1
0040-0043 : timer0
0050-0053 : timer1
0060-0060 : keyboard
0062-0062 : PNP0C09:00
0062-0062 : EC data
0064-0064 : keyboard
0066-0066 : PNP0C09:00
0066-0066 : EC cmd
0070-0077 : rtc0
0080-008f : dma page reg
00a0-00a1 : pic2
00c0-00df : dma2
00f0-00ff : fpu
0400-041f : iTCO_wdt
0680-069f : pnp 00:00
0cf8-0cff : PCI conf1
0d00-ffff : PCI Bus 0000:00
164e-164f : pnp 00:00
1800-18fe : pnp 00:00
1800-1803 : ACPI PM1a_EVT_BLK
1804-1805 : ACPI PM1a_CNT_BLK
1808-180b : ACPI PM_TMR
1830-1833 : iTCO_wdt
1850-1850 : ACPI PM2_CNT_BLK
1854-1857 : pnp 00:02
1880-189f : ACPI GPE0_BLK
d000-dfff : PCI Bus 0000:04
d000-d003 : 0000:04:00.0
d010-d017 : 0000:04:00.0
d010-d012 : parport0
d013-d017 : parport0
e000-efff : PCI Bus 0000:02
e000-e0ff : 0000:02:00.0
f000-f03f : 0000:00:02.0
f040-f05f : 0000:00:1f.4
f040-f05f : i801_smbus
ff00-fffe : pnp 00:06
ffff-ffff : pnp 00:00
06 Jun 2021 19:14 #211323 by Dragonbitscnc
Should I be looking at the PCI bus? My parallel port is pluged into PCIe slot
06 Jun 2021 19:23 - 06 Jun 2021 19:37 #211327 by PCW
Replied by PCW on topic parallel port drivers
This seems _way_ too short a step time for most step/dir drivers
try setting this to 5000 and see what happens
No linux drivers are needed (though the linux driver found your card)
LinuxCNC uses hal_parport to access the parallel port
Last edit: 06 Jun 2021 19:37 by PCW.
06 Jun 2021 19:27 #211329 by Dragonbitscnc
Ok
06 Jun 2021 19:33 #211330 by Dragonbitscnc
nothing'
Time to create page: 0.138 seconds
