Software not talking to hardware. New build
5 years 4 months ago #211388 by PCW
You actually don't know if the software is talking to the hardware or not until you can verify that you can/cannot change parallel output bits or read input bits via LinuxCNC
That's why I asked if you can see the direction signal change on the parallel port
when you jog in either direction. This will with one test eliminate all parallel port addressing and driver questions.
  • BeagleBrainz
  • New Member
  • New Member
5 years 4 months ago #211389 by BeagleBrainz
Replied by BeagleBrainz on topic Software not talking to hardware. New build
tommylight wrote: Why start a new topic with the same issue ?
Makes it really hard to keep track.
forum.linuxcnc.org/38-general-linuxcnc-q...arallel-port-drivers
I advised the OP against this.
5 years 4 months ago #211391 by Dragonbitscnc
How do I do that?
5 years 4 months ago #211393 by PCW
One way is to check if the parallel port pin that's used for direction
changes state (output voltage) when you jog in opposite directions.
  • BeagleBrainz
  • New Member
  • New Member
5 years 4 months ago #211394 by BeagleBrainz
You can either use a voltmeter or a LED with a resistor to test an output.
The positive of the voltmeter or LED to the output you want to test and the negative to the ground pin of the parallel port. You will need to use google to find a picture of a parallel port showing the signals. Ground is pins 18 - 25.
5 years 4 months ago #211396 by Dragonbitscnc
So I unplug the b.o.b. and test the parallel port pin with volt meter?
I must say when I start my machine all the steppers lock up
Time to create page: 0.124 seconds
