7i85s
16 Aug 2021 07:24 - 16 Aug 2021 11:46 #217859 by rohit269
7i85s+7i96 was created by rohit269
This browser does not support PDFs. Please download the PDF to view it: Download PDF
Sir,
I want to test 7i85s separately without connecting 7i96.
Because I want check why 7i85s not send any signal to 7i96.
Please check the picture and say is it possible this way if no so please tell what is processes of 7i85s without connected 7i96.
Thanks,
Rohit Gupta
Last edit: 16 Aug 2021 11:46 by rohit269.
16 Aug 2021 13:51 #217884 by PCW
Replied by PCW on topic 7i85s+7i96
DB25 pin 8 will reflect the inversion of encoder
0 input A when DB25 pin 7 is low and the inversion
or encoder 1 input A when DB25 pin 7 is high
Note that your switch as wired will not change the state
of the encoder input since the inputs have pullup resistors
and will rest at 5V when unconnected. For TTL inputs
you must ground the encoder input to change its state.
16 Aug 2021 14:24 #217887 by rohit269
Replied by rohit269 on topic 7i85s+7i96
Sir,
Many thanks for your reply but my encoder have only had A+, B+, 5V, 0V  (TTL,5um) so in this situation can this work.
Thanks,
Rohit Gupta
16 Aug 2021 16:19 #217893 by PCW
It should work
You should check that the encoder inputs have
valid low and high states
( < 0.8V when low and >2.4V when high )
17 Aug 2021 00:54 - 17 Aug 2021 02:26 #217938 by rohit269
Sir,
Many thanks for supporting me, one thing more also tells When I am building a LinuxCNC Step configuration for 7i85s and communicate  with it via the parallel port directly from the computer. Is  this possible?
If possible, then also tells for this purpose  in computer bios settings EPP to Be-directional  is required?
Last edit: 17 Aug 2021 02:26 by rohit269.
17 Aug 2021 02:58 #217944 by PCW
No, you cannot match the 7I85S pinout with a parallel port because of the fixed
directions of most parallel port pins
17 Aug 2021 04:21 #217949 by rohit269
Sir,
Many thanks for your reply, its mean 7i85s cannot connect and run  when  computer also accepts input 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 15 and output is 1, 14, 16, 17
17 Aug 2021 04:26 #217950 by PCW
Yes, the 7I85S I/O pin directions do not match a parallel port
17 Aug 2021 06:37 - 17 Aug 2021 06:55 #217956 by rohit269
Sir,
OH, Many thanks for your reply, but sir, our 7i85s doesn't send any  signal to 7i96 and  I am also checking this in HAL SHOW gpio pin 034 to 050 so now how to find where are problem in 7i85s. Please solve this problem.
Last edit: 17 Aug 2021 06:55 by rohit269.
17 Aug 2021 13:41 #217983 by PCW
How are the 7I96 and 7I85S power jumpers set?
Do any encoder inputs work?
Did you verify that the high and low level encoder inputs were valid ?
(greater than +2.4V for high , less than +0.8v for low)
Time to create page: 0.143 seconds
