Does it's possible to Refit.
- aleksamc
- Thank you received: 67
15 Sep 2021 18:00 #220724
by aleksamc
Replied by aleksamc on topic Does it's possible to Refit.
"Intel Celeron Inside" 1.7Ghz
Possibly this hard drive is broken. It was used ATA input.
On hard drive jumper for "master". I think it's right.
- Thank you received: 7450
15 Sep 2021 21:32 #220740
Replied by tommylight on topic Does it's possible to Refit.
It should be able to boot from USB for sure, did you enable that in BIOS ?
Jumper should be in Master for the HDD and slave on the CD if there is one connected to the same flat cable.
Try removing the CD...
- aleksamc
16 Sep 2021 04:44 #220763
by aleksamc
CD was removed before me. Possibly I need to look for new HDD.
And possibly my USB is 3.0, I think I need to use 2.0.
In BIOS USB is enabled but it's not "boot from USB". When I was PC in that time I used DVD-Rom. Possibly I need to use it one more time)))
16 Sep 2021 09:45 #220783
You woukd need to find an old HDD from that era, something from 8.4 to 20GB should work, but not all 20GB do work, this i know from experience when i changed a failed drive on a Kuka KR150, out of 5 drives i had only 2 worked.
The following user(s) said Thank You: aleksamc
- aleksamc
16 Sep 2021 14:42 #220798
by aleksamc
Tommylight, thanks I will take it to advance.
Have you had experiance to operate KUKA servodrives by linuxcnc? I think all their servos are beckhoff and use ethercat.
16 Sep 2021 17:18 #220804
No Kuka and LinuxCNC yet, and Beckhoff are used from version 4 i think, before they used an all in one till version 2, or something like that. Kind of foggy, to much to do....
- aleksamc
16 Sep 2021 17:55 - 16 Sep 2021 17:56 #220805
by aleksamc
I had some experiance with used KUKA KRC2 robots 3 years ago. It was ugly job for me. All their servos was connected with RJ45 connector in EtherCAT-like manner. All laybels was hide on that servos.
But servos there are very powerful and mouth-watering for different automation)))
Last edit: 16 Sep 2021 17:56 by aleksamc.
- db1981
- Thank you received: 276
18 Sep 2021 00:20 #220966
by db1981
Replied by db1981 on topic Does it's possible to Refit.
Hello,
I can open your tsm file, complete configuration is present.
communication with sercos could get heavy tricky.
What model of servo drives are this?
I will write about the ethercat parts later, i am out on tour a few days.
- aleksamc
18 Sep 2021 05:20 #220972
by aleksamc
Servos are: KEB 12.F5A BD-3AIA with sercos interface F5.
I can upload files from that PC to google drive.
Currently I found new hardrive and new CD-Rom for PC. I will look for CD-R disk in stores to install Windows XP.0 I hope I will find them)))
In parallel I make virtual machine with WinXP and I installing TwinCAT 2 there to look for that files. As for me it's very interesting system that made on Beckhoff and I must to study how it was built and if I could build such systems on Beckhoff futher.
So if it so openned I think I need to buy better PC and to remove old one program to it. And to repair old program.
- db1981
18 Sep 2021 09:59 #220985
by db1981
What is your actual target? getting running again with twincat? (you have to check if the plc programm is open, and that you have the gui the vendor coded...)
Or converting to linuxcnc? (to get running very fast, i would look for 'used' ethercat cards for the Kombiverts, don't wasting time on old sercos...)
Time to create page: 0.153 seconds
