Debian 10 Buster Linuxcnc iso little issues
4 years 10 months ago #230390 by AgentWD40
5. brltty causes usb serial ports to go away. Uninstall brltty
I assume this directly affects setting up a joypad then? Perfect timing! I had been preparing to setup a joypad today per the Simple Remote Pendant instructions that I saw you brought up to date earlier this year.
4 years 9 months ago #230623 by jtrantow
I think brltty would only be a problem with USB serial devices. I have had no problems with the joypad. (Well ok, I dropped the joypad on my lathe and broke a button but other machine joypads are running great.)
4 years 5 months ago - 4 years 5 months ago #242452 by JohnnyCNC
Thank You. Fortunately, I remembered this thread when I ran into the multi nm-tray problem. Now I need to know how to get the nm-tray or some other app to work so I can edit my network connections.
I just installed the 2.8.2 version from the downloads page. Then applied this fix.
P.S.  The nm-tray started working. Not sure why.
Last edit: 4 years 5 months ago by JohnnyCNC.
4 years 4 months ago #244859 by andypugh
Does anyone know how to fix this nm-tray problem in the _Installer_?
At the moment all that the installer script does is add it as a package in one file.
github.com/LinuxCNC/buster-live-build/bl...e-lists/desktop.list
Time to create page: 0.072 seconds
