Debian 10 Buster Linuxcnc iso little issues
- bevins
- Thank you received: 338
14 Nov 2021 15:41 #226480
by bevins
Debian 10 Buster Linuxcnc iso little issues was created by bevins
A couple things that bug me about this dist.
Using default with this iso uses xfce and lightdm.
1. nm-tray icon (network-manager) everytime you login it adds a new icon in the tray. I ended up with 9 of them at one point.
Fix: uninstall nm-tray with sudo apt-get remove nm-tray. logout/login reinstall with sudo apt-get install nm-tray.
logout and log back in and you should have one. Then go into MENU: settings/session and startup then select Apllication Autostart tab and remove nm-tray check in checkbox. close, logoout/login and it won't keep adding it.
2. Screen Blanking: by default it blanks screen every 600 seconds xset says.
type xset q in a terminal and you should see DPMS is Enabled
to turn this off type in terminal: cd ~ then sudo pico ./bashrc
edit at the bottom of the file and put these lines in.
export DISPLAY=;0.0
xset s off
xset s noblank
xset -dpms
then ctrl X then Y then enter
3. Synaptics won't add repository for master:
Remove the existing linuxcnc repositories, sudo apt-get update and upgrade, mark all linuxcnc for removal and apply.
For me, however I try it wont add the master buildbot repositories.
Edit /etc/apt/sources.list and add them at the end of the file save and close then sudo apt-get update and sudo apt-get upgrade and you are good to go.
Maybe this will save someone some time......
export DISPLAY=;0.0
xset s off
xset s noblank
xset -dpms
The following user(s) said Thank You: RotarySMP, phillc54, joneb, 0x2102, JohnnyCNC, AgentWD40, Flyer007, ContinenteCNC, Arnold, OliverLSedlacek
- bevins
14 Nov 2021 15:44 #226482
by bevins
Replied by bevins on topic Debian 10 Buster Linuxcnc iso little issues
after editing the .bashrc, logging out and back in type xset q and you should see that dpms is disabled.
The following user(s) said Thank You: RotarySMP, tommylight
- bevins
14 Nov 2021 15:57 #226486
by bevins
another one; autologin
edit /etc/lightdm/lightdm.conf
scroll down and uncomment the following lines:
#autologin-user=user1
#autologin-user-timeout=0
add your username to the first one, save file and reboot. IT should automatically log you in.
- RotarySMP
- Thank you received: 595
20 Nov 2021 15:50 - 20 Nov 2021 15:57 #227093
by RotarySMP
Replied by RotarySMP on topic Debian 10 Buster Linuxcnc iso little issues
Do you have any idea what I need to do to address the nm-tray failing to open it's editor, please? Here is the behaviour...
forum.linuxcnc.org/26-turning/41498-scha...fit?start=270#227091
I also have the multiple instances of nm-tray, so I tried your remove, but get:
Regards,
Mark
Regards,
Mark
Last edit: 20 Nov 2021 15:57 by RotarySMP.
- Thank you received: 7478
20 Nov 2021 16:16 #227099
Replied by tommylight on topic Debian 10 Buster Linuxcnc iso little issues
logout login means you log out and in after removing nm-tray so they should not be on the command line, at least i do not think they belong there.
- bevins
20 Nov 2021 17:23 #227106
by bevins
its just sudo apt-get remove nm-tray
- bevins
20 Nov 2021 17:24 #227108
by bevins
nm-tray isreal buggy in debian 10
- RotarySMP
20 Nov 2021 19:34 #227118
by RotarySMP
Thanks guys. I'll try that.
- RotarySMP
20 Nov 2021 20:45 - 20 Nov 2021 20:56 #227123
by RotarySMP
Where do I find this menu?
"MENU: settings/session and startup then select Application Autostart tab and remove nm-tray check in checkbox."
Also, in the instructions to turn of the screen saver, you first check xset q,
and then cd ~
cd ~ didnt change directory, as I was already in my home directory , but I have no idea where xset is located, so the pico command just opened a new blank text file, rather than editing xset's config file.
and then cd ~
Last edit: 20 Nov 2021 20:56 by RotarySMP.
- RotarySMP
20 Nov 2021 20:59 #227124
by RotarySMP
Autologin, there are two instances of autologin. One under [Lightdm], and one under [seats]. It is the instance under [seats] which makes the change.
Time to create page: 3.487 seconds
