Converting an old DMU 50, where to start?
- ihavenofish
- Thank you received: 286
28 Nov 2021 16:32 #227819
by ihavenofish
Replied by ihavenofish on topic Converting an old DMU 50, where to start?
im also curious now, you show 2 of the axis motors, both have brakes. i wonder if all 3 do as some sort of safety feature.
- einarak
- Thank you received: 3
28 Nov 2021 20:06 #227841
by einarak
Replied by einarak on topic Converting an old DMU 50, where to start?
Yes, they all do have brake. The brake is connected parallel on all motors and seems to be only for emergency stopping
- ihavenofish
28 Nov 2021 21:23 #227846
by ihavenofish
interesting
dmg/maho has always had pretty advanced safety. my late 80's machine had clutches on each axis for crash protection and a even camera to detect broken tools.
looks like you are in good shape then, interested to see where this goes. may people convert older maho's which can be bought for pennies. this is the first "modern era" dmg ive seen being done.
i no longer have the power to run a machine like this sadly, gotta stick with the little stuff.
- einarak
28 Nov 2021 21:37 #227848
by einarak
Yes, I´m super exited, I´ve allready prepaired the garage with a 5q10 cable on 63 amps, the ol´girl needs some power! Now I just need the specialists to chime in on whats boards to use, budget around 1000-2000$ (if thats what we need, but ofcourse less is better and leaves more $$$ on the table for cool hop ups!)
- ihavenofish
28 Nov 2021 21:48 #227849
by ihavenofish
Well the baseline would be the mesa 7i77, or the newer ethernet variant (7i97), However you will likely need 1 or more extra IO cards, although with no atc or gears it should be relatively simple.
If this is a running machine, i would first power it under the tnc124 and see what every function does.
- einarak
28 Nov 2021 23:15 #227857
by einarak
So this kit would bring me everything I need to get things up and running?
77I7 + 5I25
store.mesanet.com/index.php?route=produc...oduct&product_id=214
And ofcourse a moderate PC with a PCI slot...
But the 7I97 does that one not need the 5I25 card? Does it connect to the pc through the ethernet cable or what? That would be handy, cause it would open up the possability to use these new small pc´s that have no pci slot...
77I7 + 5I25
- Thank you received: 7500
28 Nov 2021 23:26 #227858
Replied by tommylight on topic Converting an old DMU 50, where to start?
7i97 does NOT need 5i25, and it does connect to the PC through an ethernet cable.
- Henk
- Thank you received: 92
29 Nov 2021 04:06 #227870
by Henk
Replied by Henk on topic Converting an old DMU 50, where to start?
I would go for a 7i94 +7i77. Then you can add io using 7i70 and 7i71's.
Or as mentioned 7i97 but add a 7i74 and 7i70/71's as required
- ihavenofish
29 Nov 2021 05:26 #227872
by ihavenofish
so those 2 options effectively do the same thing, both ethernet solutions with 8 ports of serial expansion. option 1 is $30 cheaper. in around $500 total depending on how many extra io boards you end up needing.
you get 6 servo axes with encoder feedback. you need XYZ and Spindle, then you can add both your rotary table axes on if you can figure out how.
- einarak
29 Nov 2021 10:45 #227881
by einarak
Thanks for the input, how does the 7i94 connect to the 7i77 since the 77 has db25 pin connector but 94 has ethernet and 26 pin idc
Time to create page: 1.660 seconds
